inlet rotation (moving) udf
Old   July 26, 2023, 09:18
Default inlet rotation (moving) udf
sunny
qwerty010 is on a distinguished road
hello.
I am currently doing rpb (rotation packeb bed) simulation and my geometry is roughly as follows.
As a result of referring to various papers, most of them said that rotation is implemented by creating a udf that rotates the inlet, so I also created a udf using define_cg_motion and define_grid_motion. However, when running fluent, an error occurs and the simulation does not proceed.
The udf I wrote is as follows.
#define PI 3.141592654
#define rpm 1000.0
#define inlet_ID 6
#define d 0.001 /* Nozzle width (m) */
#define R 0.019 /* radius of liquid inlet (m) */
DEFINE_CG_MOTION(rotating,dt,vel,omega,time,dtime)
double w;
Thread *t;
face_t f;
real NV_VEC(A);
real force_x, dv;
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
if (!Data_Valid_P())
return;
w = rpm * 2.0 * PI / 60.0;
omega[0] = w;
omega[1] = w;
Referenced papers are as follows:
https://doi.org/10.1016/j.cep.2020.108107
https://doi.org/10.1016/j.cej.2021.130874
Do I need to use another udf macro to move the boundary like an inlet?
Or is there something wrong with my udf code?
I need your help..please..
thank you
qwerty010 is offline   Reply With Quote
2D rotating detonation simulation - UDF inlet BC Tianxu FLUENT 10 July 27, 2020 03:28
UDF Velocity profile at inlet aar007 Fluent UDF and Scheme Programming 1 June 28, 2020 23:43
UDF for moving wall (oscillating) Sambhu.jayachandran Fluent UDF and Scheme Programming 3 March 12, 2018 04:23
UDF problem : inlet velocity in cyl. coord. system Jongdae Kim FLUENT 0 June 15, 2004 12:21
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
