How to work UPDATE function in UDF
Old   July 22, 2023, 14:11
Default How to work UPDATE function in UDF
Chhotelal
Chhotelal1234 is on a distinguished road
I need to define the some property UDF such as density, thermal conductivity, diameter, heat capacity, but problem is these properties is function of other parameter moisture content that will fist calculate then these values comes. What function should I define in UDF so that moisture will change every cell. Is it UPDATE function or something else?
I make the code, it compiled but floating point errors coming. I thought update function is not working. Could you please suggest me how can I solve this problem.
Chhotelal1234 is offline   Reply With Quote
Error in enabling the python wrapper Jinn SU2 Installation 2 April 23, 2022 14:52
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
