July 12, 2023, 14:31 |
Fluent UDF SIGSEGV error
Navarag KK
Rep Power: 3 |
Hey all, thanks for helping with my previous doubt and currently
I need the torque_p value to be read in the second Macro, hence using C_UDMI function. I am getting the segmentation error and fluent crashes even though I allocated the memory. (the reason i looped C_UDMI is because i dont want fluent to take the value from other cells) the UDF code is #include "udf.h" #include <mem.h> static real omega_calc = 0.0; static real theta=0.0;/*need to check*/ /*extern real omega_out=0.0; */ real torque_p; Thread* thread; cell_t cell; face_t face; DEFINE_ADJUST(torque_cal,domain) { /* Variables used by serial, host, node versions */ int surface_thread_id=9;/*door surface id from fluent*/ real total_area=0.0; torque_p=0.0; real area[ND_ND]; real NV_VEC(A); real w[ND_ND]; thread = Lookup_Thread(domain,surface_thread_id); real prep; begin_f_loop(face,thread) /* If this is the node to which face "officially" belongs,*/ /* get the area vector and pressure and increment */ /* the total area and total force values for this node */ { F_AREA(area,face,thread); total_area += NV_MAG(area); F_AREA(A,face,thread); F_CENTROID(w,face,thread); torque_p += F_P(face,thread)*NVD_DOT(A,w[1],-w[0],0);/*need to check -w[1],w[0] as per geometry*/ Message ("\npressure = %f,", prep); Message ("\ntorque = %f,", torque_p); } end_f_loop(face,thread) begin_c_loop(cell,thread); { C_UDMI(cell,thread,1)=torque_p; } end_c_loop(cell,thread); Message ("\ntorque in cell = %f,", torque_p); } DEFINE_CG_MOTION(door_move,dt,vel,omega,time,dtime ) { Message ("\ntorque in 2nd udf = %f,", torque_p); begin_c_loop(cell,thread); { torque_p=C_UDMI(cell,thread,1); } end_c_loop(cell,thread); Message ("\ntorque = %f,", torque_p); NV_S(omega, =, 0.0); real torque, domega, omega_prev, omega_dot, omega_out; real inertia = 2.4; /* Compute the torque due to pressure P and weight W */ /*-----------------------------------------------------------------------*/ torque= -torque_p ; domega = dtime * torque / inertia; omega_dot= torque / inertia; /* Calculate the angular velocity */ /*-----------------------------------------------------------------------*/ omega_prev = omega_calc; omega_calc = omega_calc + domega; omega_out = omega_calc; omega[0]=0; omega[1]=omega_out; /* Calculate the angle theta (Taylor expansion) */ /*-----------------------------------------------------------------------*/ theta=theta - 0.5*dtime*(omega_prev+omega_calc); #if !RP_NODE Message ("\ntorque_p = %f,", torque_p); Message ("\ntorque = %f,", torque); Message ("\ndomega = %f,", domega); Message ("\nomega_calc: %f\n", omega_calc); Message ("\n---------------------------------------"); Message ("\ntheta: %f\n", theta); #endif } The error is > /solve dual-time-iterate 2000 10 ================================================== ============================ Node 999999: Process 7834: Received signal SIGSEGV. ================================================== ============================ ===============Message from the Cortex Process================================ ================================================== ============================ Node 6: Process 8145: Received signal SIGSEGV. ================================================== ============================ What can I do to avoid this error or is there anyother way to transfer data from one udf to another? |
udf |
[swak4Foam] swak4foam openfoam 7 installation problem | Andrea23 | OpenFOAM Community Contributions | 1 | February 17, 2020 19:11 |
UDF for DPM particle deposition modelingpa | haghshenasfard | Fluent UDF and Scheme Programming | 10 | September 15, 2019 03:03 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 07:35 |
Mesquite - Adaptive mesh refinement / coarsening? | philippose | OpenFOAM Running, Solving & CFD | 94 | January 27, 2016 10:40 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 19:00 |
