The UDF library you are trying to load (libudf) is not compiled for parallel use on t |
June 8, 2023, 10:47 |
Rep Power: 3 |
This error is coming when i amusing option "Load" while compiling UDF . Tried all permutation nd combinations but nothing happening. I am using ansys fluent 2021R2 and Microsoft visual 2022.
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).\n\nThe system cannot find the file specified. \n\nD:\kapil\Inlcusionmodel\400mmSENSolidification speed1.4\libudf\win64\3ddp_host\libudf.dll Error Object: #f |
June 18, 2023, 22:57 |
#2 | |
Alexander
Rep Power: 34 |
your code is not compiled according to log
best regards ****************************** press LIKE if this message was helpful |
compilation, error, udf |
Difficulty in loading UDF: udf library not compiled for parallel use | Danmei | Fluent UDF and Scheme Programming | 6 | October 12, 2020 07:12 |
UDF library you are trying to load (libudf)... | ehsan105 | Fluent UDF and Scheme Programming | 6 | March 8, 2018 01:57 |
Compile udf and load libudf library | starlight | FLUENT | 5 | February 19, 2015 10:49 |
Error: The UDF library you are trying to load is not compiled for 3ddp on the current | Whitemast | Fluent UDF and Scheme Programming | 0 | November 21, 2013 07:45 |
setting up compiled UDF library in windows2000 | sivakumar | FLUENT | 1 | October 19, 2001 04:46 |
