May 22, 2023, 13:26 |
Udf ehl model- error
chris
Rep Power: 4 |
i am experiencing difficulties solving my 2d ehl case using udfs. The codes based on the original thesis are the same (correct) but when i implement them in fluent, setting my dynamic zones for the dynamic mesh(the udf which is define_grid_motion is to simulate the elastic deformation of the top roller) and press calculation i get an error: fl process could not be started. the problem seems thst is in the first itteration at the first node of the top roller gives height equal to zero( which is not possible) for the lubricant film. its like the udf doesnt recognise the rollers coordinates or something. does anyone have an idea where the problem might be? |
dynamic mesh zones, fl process not started, fluent, udf |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 01:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
How to install CGNS under windows xp? | lzgwhy | Main CFD Forum | 1 | January 11, 2011 19:44 |
Problem with compile the setParabolicInlet | ivanyao | OpenFOAM Running, Solving & CFD | 6 | September 5, 2008 21:50 |
