temperature difference from different zones using UDF
Old   May 18, 2023, 09:45
Post temperature difference from different zones using UDF
Mohammad
Selawe97 is on a distinguished road
Hello Dears,
My problem is I am using a UDF code to collect temperature values at different cell zones (solid region and fluid region). I am saving temperature values in arrays (as shown in the code) by looping over them and using them later to get the temperature difference to use it in a formula for the fluid cell zone.
in (c0_array[n]) and (c1_array[n]) the data was saved as I want in the first two loops
(begin_c_loop(c01,ft1)
and
begin_c_loop(c02,ft2))
, and they saved correctly, but when I loop them inside the third loop
(begin_c_loop(c, t))
to receive the data saved in the first two loops the values of (c0_array[n]) in the third loop are saved correctly as I want, but for (c1_array[n]) the data became chaotic and disorganized! so why do I get something like that?
knowing both zones are coincided and have the same number of cells. and I have to use the define profile macro.
#include "udf.h"
#include "mem.h"
DEFINE_PROFILE(HTC, t, position)
    Domain* domain = Get_Domain(1);
    Thread* ft1 = Lookup_Thread(domain, 2);
    Thread* ft2 = Lookup_Thread(domain, 4);
    cell_t c, c01, c02;
    Thread* t01, t02;
    int n;
    real c0_array[10000], c1_array[10000];
    n = 0;
    begin_c_loop(c01, ft1)
        C_UDMI(c01, ft1, 0) = C_T(c01, ft1);
        c0_array[n] = C_T(c01, ft1);
		C_UDMI(c01, ft1, 1) = c0_array[n];
        n++;
    end_c_loop(c01, ft1)
    n = 0;
    begin_c_loop(c02, ft2)
        C_UDMI(c02, ft2, 2) = C_T(c02, ft2);
        c1_array[n] = C_T(c02, ft2);
		C_UDMI(c02, ft2, 3) = c1_array[n];
        n++;
    end_c_loop(c02, ft2)
    n = 0;
    begin_c_loop(c, t)
        C_UDMI(c, t, 4) = c0_array[n]; // or C_UDMI(c,t,2)= c0_array[n] - c1_array[n];
        C_UDMI(c, t, 5) = c1_array[n];
        C_PROFILE(c, t, position) = C_UDMI(c, t, 4)-C_UDMI(c, t, 5);
        C_UDMI(c, t, 6) = C_PROFILE(c, t, position);
        n++;
    end_c_loop(c, t)
Your help is appreciated,
Thanks
Selawe97 is offline   Reply With Quote
array, cell zones, collect data, temperature difference
Saturation temperature UDF for evaporation-condensation obiscolly50 Fluent UDF and Scheme Programming 1 June 20, 2021 11:08
Heat flux as a function of wall temperature using UDF Piquero FLUENT 2 May 7, 2021 13:02
UDF problem- time dependent temperature at inlet kaeran FLUENT 1 June 16, 2015 22:48
UDF for variable temperature with time CaglarCoskun Fluent UDF and Scheme Programming 8 January 15, 2014 10:15
Inlet won't apply UDF and has temperature at 0K! tccruise Fluent UDF and Scheme Programming 2 September 14, 2012 07:08
