May 16, 2023, 12:31 |
Adding a source term in Fluent_(real dS[])
Raja Ganesh
Hello everyone,
I am new to UDF and I am working on adding a source term to a VOF model. I am trying to understand the "real dS[]" term. On going through the Fluent UDF manual, I understood that this is a derivate term of the dependent variable in the transport equation. But I am not clear about the two options that Fluent provides, ds[equ] = ds/d(phi) (for implicit) ds[equ] = 0.0 (for explicit). Can someone explain, when should i choose the derivate term to be the real derivate and when should i just enter 0.0 as the derivative value? Thanks. |
derivative, fluent - udf, source code, udf code, udf c_vof |
[OpenFOAM.com] swak4foam compiling issues on a cluster | saj216 | OpenFOAM Installation | 5 | January 17, 2023 16:05 |
polynomial BC | srv537 | OpenFOAM Pre-Processing | 4 | December 3, 2016 09:07 |
SparceImage v1.7.x Issue on MAC OS X | rcarmi | OpenFOAM Installation | 4 | August 14, 2014 06:42 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
