Two dimensional pipe flow show zero VELOCITY on outlet boundary |
May 1, 2023, 11:25 |
Haider Ali
Rep Power: 3 |
I am trying to perform flow in two dimensional pipe. The pipe consist of inlet, outlet, lower wall and upper wall as boundary condition. I am trying to induce sinusoidal wave in lower wall using Dynamic mesh technique. The user defined function is complied and assign to lower wall, so it can generate fluid flow. My problem is that velocity contours shows zero velocity on outlet boundary Note: I am trying to generate flow using wall movement only. There is no pressure difference across inlet and outlet. Any help is greatly appreciated. |
fluent, sinewave, udf |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Non-uniform velocity at outlet when using mass flow rate boundary condition | Julian121 | CFX | 4 | June 10, 2019 07:39 |
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Boundary condition of velocity and pressure at interface for air water pipe flow | jignesh_thaker2007 | OpenFOAM Running, Solving & CFD | 0 | June 10, 2014 16:42 |
Why we normally provide velocity at inlet and pressure at outlet for pipe flow? | p07ip705 | Main CFD Forum | 3 | August 3, 2012 05:53 |
