Help me parallelize a serial UDF (UDS computed on each cell and faces) |
April 13, 2023, 14:17 |
Hank
Hello all,
I am trying to convert a serial UDF (which works fine in a single core) to work in a parallel environment (higher cores). Here is the UDF in a single-core setting, #include "udf.h" #include "mem.h" #include <stdio.h> #include <math.h> #define Q 60.e-06 #define e0 8.854e-12 // Define which user defined scalars to use enum { phi, /* 0 - Electric potential*/ E, /* 1 - Electric field*/ Fdix, /* 2 - x-component Dielectrophoretic force*/ }; DEFINE_ADJUST(Adjust_fun, domain) { cell_t c; face_t f; real dp= 300.0e-09; //particle diameter real ep = 4.6; //relative permittivity of particle Thread *t; ; real coff = M_PI*e0*pow(dp,3)*((ep-1)/(ep+2))*0.25/(2130.0*M_PI*pow(dp,3)/6.); // coefficienct in polarization force calculation // Calculating Electric field E and the X-force Fdix from the potential (phi) thread_loop_c(t,domain) { begin_c_loop(c,t) { C_UDSI(c,t,E) = NV_MAG(C_UDSI_G(c,t,phi)); if(C_UDSI(c,t,E)<=0.0) C_UDSI(c,t,E)=0.0; if(C_UDSI(c,t,E)>(Q/e0)) C_UDSI(c,t,E) = Q/e0; C_UDSI(c,t,Fdix) = (2.*coff*C_UDSI(c,t,E)*(C_UDSI_G(c,t,E)[0])); } end_c_loop(c,t) } // Calculating the electrostatic force F on the face of the cell thread_loop_f(t,domain) { begin_f_loop(f,t) { if(NULL !=THREAD_STORAGE(t, SV_UDS_I(phi)) && NULL != T_STORAGE_R_NV(t->t0,SV_UDSI_G(phi))) F_UDSI(f,t,E)=C_UDSI(F_C0(f,t), t->t0, E); if(NULL != THREAD_STORAGE(t,SV_UDS_I(E))&& NULL != T_STORAGE_R_NV(t->t0, SV_UDSI_G(E))) { F_UDSI(f,t,Fdix)=C_UDSI(F_C0(f,t), t->t0, Fdix); } } end_f_loop(f,t) } } The code calculates the electrostatic field in all the cells and faces of the domain from the potential values obtained from solving the scalar transport equation. The electrostatic force is then calculated from the electrostatic field. So far I have tried looping over interior cells and principal faces only. #include "udf.h" #include "mem.h" #include <stdio.h> #include <math.h> #define Q 60.e-06 #define e0 8.854e-12 // Define which user defined scalars to use enum { phi, /* 0 - Electric potential*/ E, /* 1 - Electric field*/ Fdix, /* 2 - x-component Dielectrophoretic force*/ }; DEFINE_ADJUST(Adjust_fun, domain) { #if !RP_HOST cell_t c; face_t f; real dp= 300.0e-09; //particle diameter real ep = 4.6; //relative permittivity of particle Thread *t; ; real coff = M_PI*e0*pow(dp,3)*((ep-1)/(ep+2))*0.25/(2130.0*M_PI*pow(dp,3)/6.); // coefficienct in polarization force calculation // Calculating Electric field E and the X-force Fdix from the potential (phi) thread_loop_c(t,domain) { begin_c_loop_int(c,t) { C_UDSI(c,t,E) = NV_MAG(C_UDSI_G(c,t,phi)); if(C_UDSI(c,t,E)<=0.0) C_UDSI(c,t,E)=0.0; if(C_UDSI(c,t,E)>(Q/e0)) C_UDSI(c,t,E) = Q/e0; C_UDSI(c,t,Fdix) = (2.*coff*C_UDSI(c,t,E)*(C_UDSI_G(c,t,E)[0])); } end_c_loop_int(c,t) } // Calculating the electrostatic force F on the face of the cell thread_loop_f(t,domain) { begin_f_loop(f,t) { if PRINCIPAL_FACE_P(f,t) { if(NULL !=THREAD_STORAGE(t, SV_UDS_I(phi)) && NULL != T_STORAGE_R_NV(t->t0,SV_UDSI_G(phi))) F_UDSI(f,t,E)=C_UDSI(F_C0(f,t), t->t0, E); if(NULL != THREAD_STORAGE(t,SV_UDS_I(E))&& NULL != T_STORAGE_R_NV(t->t0, SV_UDSI_G(E))) { F_UDSI(f,t,Fdix)=C_UDSI(F_C0(f,t), t->t0, Fdix); } } } end_f_loop(f,t) } #endif } However, it did not result in correct values. The electrostatic field values and forces did not even converge. I also tried just looping over the compute nodes over all the faces and cells as shown, #include "udf.h" #include "mem.h" #include <stdio.h> #include <math.h> #define Q 60.e-06 #define e0 8.854e-12 // Define which user defined scalars to use enum { phi, /* 0 - Electric potential*/ E, /* 1 - Electric field*/ Fdix, /* 2 - x-component Dielectrophoretic force*/ }; DEFINE_ADJUST(Adjust_fun, domain) { #if !RP_HOST cell_t c; face_t f; real dp= 300.0e-09; //particle diameter real ep = 4.6; //relative permittivity of particle Thread *t; ; real coff = M_PI*e0*pow(dp,3)*((ep-1)/(ep+2))*0.25/(2130.0*M_PI*pow(dp,3)/6.); // coefficienct in polarization force calculation // Calculating Electric field E and the X-force Fdix from the potential (phi) thread_loop_c(t,domain) { begin_c_loop(c,t) { C_UDSI(c,t,E) = NV_MAG(C_UDSI_G(c,t,phi)); if(C_UDSI(c,t,E)<=0.0) C_UDSI(c,t,E)=0.0; if(C_UDSI(c,t,E)>(Q/e0)) C_UDSI(c,t,E) = Q/e0; C_UDSI(c,t,Fdix) = (2.*coff*C_UDSI(c,t,E)*(C_UDSI_G(c,t,E)[0])); } end_c_loop(c,t) } // Calculating the electrostatic force F on the face of the cell thread_loop_f(t,domain) { begin_f_loop(f,t) { if(NULL !=THREAD_STORAGE(t, SV_UDS_I(phi)) && NULL != T_STORAGE_R_NV(t->t0,SV_UDSI_G(phi))) F_UDSI(f,t,E)=C_UDSI(F_C0(f,t), t->t0, E); if(NULL != THREAD_STORAGE(t,SV_UDS_I(E))&& NULL != T_STORAGE_R_NV(t->t0, SV_UDSI_G(E))) { F_UDSI(f,t,Fdix)=C_UDSI(F_C0(f,t), t->t0, Fdix); } } end_f_loop(f,t) } #endif } the values do not match the results from a single core. If anyone has any advice on how I can parallelize the UDF it would be of great help. Thank you. Hank |
#uds #parallelize |
[snappyHexMesh] snappyHexMesh does not detect highly skewed faces? | ptpacheco | OpenFOAM Meshing & Mesh Conversion | 1 | January 4, 2022 13:37 |
[snappyHexMesh] Layers not growing at all | zonda | OpenFOAM Meshing & Mesh Conversion | 12 | June 6, 2020 12:28 |
[snappyHexMesh] sHM layer process keeps getting killed | MBttR | OpenFOAM Meshing & Mesh Conversion | 4 | August 15, 2016 04:21 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
snappyhexmesh remove blockmesh geometry | philipp1 | OpenFOAM Running, Solving & CFD | 2 | December 12, 2014 11:58 |
