Fluent Scheme to change value of a boundary condition |
Jad Diab
Rep Power: 4 ![]() |
Dear all,
for some particular reason on a fluent module, I cannot change the boundary condition value as udf (it only takes values and not udf) I believe I can automate this using a scheme instead of a udf to overcome this issue Could anyone link me to an example of a scheme that changes a boundary condition value (and not type) with time? I am not very familiar with schemes |
Odisha
Rep Power: 6 ![]() |
You can record a journal file while you set up your boundary conditions. This journal file will contain the 'scheme' commands, which you can later on manipulate with some basic understanding of Scheme.
There's a Scheme manual available online. |
fluent, scheme, udf |
Fluent change boundary condition type using Scheme syntax in journal file | lytemar | Fluent UDF and Scheme Programming | 4 | April 28, 2022 02:13 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
CFX fails to calculate a diffuser pipe flow | shenying0710 | CFX | 7 | March 26, 2013 04:13 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
