March 8, 2023, 07:53 |
UDF not compiling
Amir Khan
Rep Power: 3 |
Hi everyone,
I am trying to compile the following UDF and it runs without the data saving part but as soon as I add this Code:
#if RP_HOST fp = fopen("data.txt", "a"); fprintf(fp,"%g %g %g %g %g \n",time,cg[1],vel[1],cg[2],omega[1]) fclose(fp); #endif Code:
#include "udf.h" #include "math.h" #include <stdio.h> static real v_prev_y = 0.0; static real v_prev_theta = 0.0; DEFINE_CG_MOTION(flapping,dt,vel,omega,time,dtime) { Thread *t; Domain *d; FILE *fp; real cg[3]; real force[3]; real moment[3]; real accl_y; real dv_y; real accl_theta; real dv_theta; real ured = 10; real mass_y = 63.9; real eta = 0.01; real ro = 1.0; real c_y = 0; real k_y = 289.5; real c_theta = 0.501; real k_theta = 0; real lambda = -0.0033; real l_theta = 0.067; real I_theta = 0.146 ; int i; NV_S(vel,=,0.0); NV_S(omega,=,0.0); t = DT_THREAD(dt); d = Get_Domain(1); cg[1]=DT_CG(dt)[1]; cg[2]=DT_THETA(dt)[2]; Compute_Force_And_Moment(d,t,cg,force,moment,TRUE); force[1] += -k_y * cg[1] - c_y * vel[1]; moment[2] += -k_theta * cg[2] - c_theta * omega[2]; accl_y = force[1]/mass_y; accl_theta = moment[2]/I_theta; dv_y = accl_y * dtime; dv_theta = accl_theta * dtime; v_prev_y += dv_y; v_prev_theta += dv_theta; vel[1] = v_prev_y; omega[2] = v_prev_theta; #if RP_HOST fp = fopen("data.txt", "a"); fprintf(fp,"%g %g %g %g %g \n",time,cg[1],vel[1],cg[2],omega[1]) fclose(fp); #endif } |
March 9, 2023, 03:14 |
Odisha
Rep Power: 6 |
Hi. You should try this instead:
#if !RP_HOST . . . #endif |
March 13, 2023, 06:06 |
Amir Khan
Rep Power: 3 |
I get the following after building.
Copied C:\Users\engra\OneDrive - National University of Sciences & Technology\UDFs\UDF_Passive_Flapping - Copy.c to libudf\src Creating user_nt.udf file for 2ddp_host ... (system "copy "C:\PROGRA~1\ANSYSI~1\v201\fluent"\fluent20.1.0\src\udf\makefile_nt.udf "libudf\win64\2ddp_host\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\2ddp_host")Creating user_nt.udf file for 2ddp_node ... (system "copy "C:\PROGRA~1\ANSYSI~1\v201\fluent"\fluent20.1.0\src\udf\makefile_nt.udf "libudf\win64\2ddp_node\makefile" ") 1 file(s) copied. (chdir "libudf")(chdir "win64\2ddp_node") Done. Code:
Error at Node 23: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64). The system cannot find the file specified. |
udf, udf compilation, udf compile |
UDF compiling error | Weiqiang Liu | FLUENT | 2 | November 21, 2018 10:36 |
UDF Compiling / Parallel mode | MV78 | Fluent UDF and Scheme Programming | 6 | May 29, 2018 06:02 |
ERROR in compiling UDF | stefanos | Fluent UDF and Scheme Programming | 1 | April 25, 2012 08:37 |
udf compiling problem | akr | FLUENT | 3 | August 22, 2007 08:14 |
On Compiling a UDF | David Chabot | FLUENT | 5 | May 20, 2005 10:13 |
