turbulent energy dissipation rate
Old   February 23, 2023, 11:20
Default turbulent energy dissipation rate
whydi is on a distinguished road
i have a hopefully simple question for using UDF.
I try to implement a new coalescence kernel for PBM.
This contains the turbulent energy dissipation rate epsilon.
I am using:
eps = C_D(cell, tm);
turbulence model is RNG k-epsilon.
I get a SIGSEGV
The fl process could not be started.
I know its about epsilon because error does not occur when using eps = const.
what do i have to consider? Do i have to save epsilon?
Thank you.
whydi is offline   Reply With Quote
Old   February 24, 2023, 06:05
Update:
As i told I am using RNG k-epsilon model, where epsilon should be saved.
What i did not considered is the "dispersed" option, which is only calculating epsilon for primary liquid phase.
So I changed my code in Aggregation kernel into:
epsi = C_D(cell, tp)
with:
*/ Thread *tp as primary liquid phase */
Additional information: Theory Guide uses epsilon(liquid phase) for prince&blanch aggregation kernel for bubbles as well.
No error occurs!
Does anyone know if this approach is valid?
thanks
energy dissipation, rng k-epsilon, sigsegv
How is turbulent kinetic energy and dissipation rate calculated? Manideep304 Main CFD Forum 3 June 29, 2020 03:31
Turbulence kinetic energy and dissipation rate - problem with computation Kozan Main CFD Forum 0 March 6, 2015 05:04
how to define the turbulent kinetic energy and turbulent dissipation rate? fanke FLOW-3D 4 March 26, 2013 21:40
turbulent kinetic energy and turbulent dissipation rate D_L Main CFD Forum 5 July 17, 2010 03:35
ATTENTION! Reliability problems in CFX 5.7 Joseph CFX 14 April 20, 2010 16:45
