Face centroid value for interior between porous media and fluid |
February 16, 2023, 19:42 |
Rep Power: 4 |
Hi guys,
This is might be a really dumb question. What velocity value should the face centroid between the porous media and the fluid be if the porous media uses physical velocity? I tried to simulate a 2d axisymmetric pipe flow and use F_V(f,t) to get the radial velocity, but it seems like if I use this macro, I would receive error messages. The code works fine if I delete F_V(f,t). Is it because fluent can't determine that? But everything should be continuous right? Thank you! |
Porous media setup issues in Fluent | Bernard Van | FLUENT | 29 | January 26, 2017 05:09 |
Interface between Fluid and Homogeneous Porous Media | guilbemloco | FLUENT | 0 | June 11, 2015 10:18 |
fluid flowing through the porous media | fairuz_hafizan | Main CFD Forum | 3 | March 1, 2011 16:11 |
spercritical fluid flow in porous media | cachen | FLUENT | 3 | November 10, 2007 03:20 |
porous media: Fluent or Star-CD? | Igor | Main CFD Forum | 0 | December 5, 2002 16:16 |
