Global variables were initialized to 0
Old   February 16, 2023, 12:34
Default Global variables were initialized to 0
Mars35 is on a distinguished road
Hi guys,
I have define_init to read a text file and store my data in an array (global variable). This was working fine. In the same C file, I also used define_profile such that as long as my position coordinate matches, I would use the velocity at that coordinates. However, it was not working. Because I found out the arrays that stored my coordinates data was 0. I went to check on post on C program which I found the static and global variables were initialized to 0.
Is there other ways that I can keep my values in array? Thank you.
Mars35 is offline   Reply With Quote
Old   February 16, 2023, 14:27
Smile Problem solved
Hi guys,
The problem was solved without defining a global variable. However, it would still be great if I could learn how to update the values for global variable in the UDF. Thank you for reading this post and have a nice day!
courant number increases to rather large values 6863523 OpenFOAM Running, Solving & CFD 22 July 6, 2023 00:48
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" bigphil OpenFOAM CC Toolkits for Fluid-Structure Interaction 686 December 22, 2022 10:10
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 16:53
Micro Scale Pore, icoFoam gooya_kabir OpenFOAM Running, Solving & CFD 2 November 2, 2013 14:58
lid-driven cavity in matlab using BiCGStab Don456 Main CFD Forum 1 January 19, 2012 16:00
