Fluent crashes when running simulation with Matlab |
February 8, 2023, 13:19 |
Rep Power: 14 |
dear All,
I am now running Fluent with specifying those parameters via Matlab. Results are extracted using UDF from Fluent and then processed by Matlab to decide whether additional simulation should be executed. The iteration calculation is controlled via the command of case 1 iFluentTuiInterpreter.doMenuCommandToString('solve set number-of-time-steps 200'); iFluentTuiInterpreter.doMenuCommandToString('solve dual-time-iterate'); or iFluentTuiInterpreter.doMenuCommandToString('solve iterate'); case 2 iFluentTuiInterpreter.doMenuCommandToString('solve dual-time-iterate 200 200'); generally, it works well. But, while the multiple of Time-step used in Autosave and Time-step specified in the Calculate panel are coincidentally equal (for example, per 100 timesteps for autosaving and 200 timesteps for calculation), Fluent would crash at the end of the last iteration with following Error Information No error handler available Error: Cortex received a fatal signal (SEGMENTATION VIOLATION). Error Object: () can anybody help? many thanks |
Some questions about flow boiling simulation in Fluent | beastieboys6 | FLUENT | 8 | November 21, 2017 00:47 |
Fuel Spray Simulation - How to go about it using fluent? | hadiniesta | FLUENT | 2 | May 26, 2017 03:12 |
Replacing mesh while running a simulation | akultane | CFX | 1 | November 15, 2009 14:46 |
Statically Compiling OpenFOAM Issues | herzfeldd | OpenFOAM Installation | 21 | January 6, 2009 10:38 |
Kubuntu uses dash breaks All scripts in tutorials | platopus | OpenFOAM Bugs | 8 | April 15, 2008 08:52 |
