How to use a UDF to assign a temperature to cells that is within a range of z coord
Old   January 23, 2023, 10:38
Default How to use a UDF to assign a temperature to cells that is within a range of z coord
Khanh Dang
kdang is on a distinguished road
Could I get help with writing my first UDF in Fluent? I have written a UDF to assign a temperature to the cells whose z-coordinates are within a specified range. But it doesn't seem to work. Could everyone take a look at my code and point what I have done wrong?
I'm doing a series of transient simulations of the heat transfer between food cans and hot gas in a convection oven. I have a 228-in length filled with cans, and the can locations are periodic such that there are 19 units of cans. Each unit is 12 in long.
I want to use the UDF to set an initial temperature for the first unit of cans (Unit 1) and then solve for 16 s. Then, the current temperature of the Unit 1 will be the initial temperature of Unit 2. I will repeat this procedure until Unit 19.
I used DEFINE_ON_DEMAND instead of DEFINE_INIT because I'm using a steady-state solution as the initial solution for the hot gas.
Thank you so much in advance for your time and help!
#include "udf.h"
DEFINE_ON_DEMAND(can_unit_1_temp)
	/* declare domain pointer since it is not passed as an argument to the DEFINE macro */
	Domain *domain;
	domain = Get_Domain(1);
	/* get the cell thread pointer by using the macro Lookup_Thread(domain, zone_id) instead of thread *ct */
	int id = 55; /* ID of can solid cell zone */
	Thread *ct = Lookup_Thread(domain, id);
	cell_t c; /* cell index - an special Ansys Fluent data type */
	real pos[ND_ND];
	/* loop through all the cells in the cell thread of the can solid */
	begin_c_loop(c,ct)
		C_CENTROID(pos,c,ct);
		if (0.1524 < pos[2] && pos[2] < 0.4572) /* the first 12 inch of cans (unit 1) is between 0.1524 and 0.4572 m */
			C_T(c,ct) = 600.0;
	end_c_loop(c,ct)
kdang is offline   Reply With Quote
Old   February 4, 2023, 11:52
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
code seems to be ok
by default fluent uses SI for all UNITs so check your values, that could be a problem
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
[snappyHexMesh] snappyHexMesh sticking point natty_king OpenFOAM Meshing & Mesh Conversion 11 February 20, 2024 10:12
SimpleFoam & Theater jipai OpenFOAM Running, Solving & CFD 3 June 18, 2019 11:11
cellZone not taking all the cells inside rahulksoni OpenFOAM Running, Solving & CFD 6 January 25, 2019 01:11
[snappyHexMesh] sHM layer process keeps getting killed MBttR OpenFOAM Meshing & Mesh Conversion 4 August 15, 2016 04:21
[Netgen] Import netgen mesh to OpenFOAM hsieh OpenFOAM Meshing & Mesh Conversion 32 September 13, 2011 06:50
