Basic UDF examples
Old   January 22, 2023, 19:47
Default Basic UDF examples
Brett
Bdew8556 is on a distinguished road
Hey all,
After many years of using CFX I'm back using Fluent.
I'm working on a model of an aircraft with an engine.
Ive got the following BCs for my Engine
Engine Inlet (so CFD/domain outlet)
Pressure BC
Engine Outlet (again, so domain inlet)
Mass flow rate BC
I'm hoping to write a UDF that reads in the value I set for the Engine Outlet mdot, then adjusts the Engine Inlet Pressure to match the Engine Outlet mdot minus fuel.
I think this is somewhat simple but I'm a complete novice with UDFs.
Any thoughts?
Bdew8556 is offline   Reply With Quote
Old   January 30, 2023, 17:32
Brett
Could you perhaps point me to some of them?
Old   February 1, 2023, 07:34
Kirk d. Sutton
KirkSutton is on a distinguished road
I'm using Fluent again after using CFX for a very long time.
I'm developing a model of an engine-powered aeroplane.
The following BCs are available for my engine.
Engine Inlet Pressure (so CFD/domain Outlet) BC
Engine Exit (again, so domain inlet)
BC mass flow rate
A UDF that reads the value I specify for the Engine Outlet mdot and then modifies the Engine Inlet Pressure to match the Engine Outlet mdot less fuel is what I'm aiming to create.
I believe this to be quite straightforward, but I have no experience with UDFs.
KirkSutton is offline   Reply With Quote
fluent - udf, programming, udf code
can anyone help me about the udf of dynamic contact angle in FLUENT? Albert Lee FLUENT 0 July 1, 2018 09:21
Mass Source Term UDF, Basic Gomaa Fluent UDF and Scheme Programming 0 April 15, 2018 01:13
basic question about defining time and time period in udf raminostadi Fluent UDF and Scheme Programming 0 November 30, 2016 04:31
Dynamic mesh examples using Fluent 6.1 and Udf RAMESH K FLUENT 2 July 22, 2010 23:47
need some basic help with fluent udf aarti sekaran FLUENT 8 February 12, 2008 01:57
