Writing a UDF to get the coordinates of the center of mass of a rising bubble |
January 18, 2023, 06:14 |
Elliott
Rep Power: 4 |
Hello, I am using fluent to simulate a rising bubble in a column of water. The bubble is an oil bubble and the simulations are made in 2D axisym.
I would like to get the terminal velocity of the bubble and have decided to use a UDF to get the center of mass of the bubble. However this is my first UDF and the results I get is always 0 and I do not know where the problem comes from. I hope somebody will be able to help me out here. Thank you very much The udf I wrote : Code:
#include "udf.h" #include <math.h> DEFINE_EXECUTE_AT_END(execute_at_end) { int phase_domain_index; Domain *subdomain; Domain *mixture_domain; mixture_domain = Get_Domain(1); double num; num = 0.0; double denom; denom = 0.0; double bar; double vol; vol = 6.25e-8; double rho; rho = 974.5; #if !RP_HOST FILE *file = fopen("data.txt", "a"); if(!file) { Message("Cannot open the file"); } else { /*loop over all subdomain(phases) in the superdomain(mixture)*/ sub_domain_loop(subdomain, mixture_domain, phase_domain_index) { Thread *cell_thread; cell_t cell; real xc[ND_ND]; /*loop over all cell threads in the domain*/ thread_loop_c(cell_thread, subdomain) { /*loop over all cells in the thread*/ begin_c_loop_all(cell, cell_thread) { /*get the cell centroid*/ C_CENTROID(xc, cell, cell_thread); num = num + C_VOF(cell, cell_thread)*xc[0]*rho*vol; denom = denom + C_VOF(cell, cell_thread)*rho*vol; } end_c_loop_all(cell, cell_thread) } } } bar = num/denom; fprintf(file,"Resultats: %g\n",bar); fclose(file); #endif } Last edited by edems86; January 18, 2023 at 10:55. |
rising bubble, udf |
Defining UDF function for Time-dependent mass flow | cfdstudent12 | FLUENT | 0 | June 27, 2022 04:09 |
Bubble expansion due to mass transfer from liquid | richard222 | Fluent Multiphase | 1 | July 2, 2018 08:34 |
UDF for mass and heat source with heat transfer | rajendra1 | Fluent UDF and Scheme Programming | 35 | October 13, 2017 05:04 |
bubble rising problem | swamysrikanth | ANSYS Meshing & Geometry | 3 | May 31, 2016 12:09 |
Mass source UDF | epc1 | Fluent UDF and Scheme Programming | 1 | January 24, 2013 10:24 |
