Calculation of Physiological Equivalent Temperature Index using UDF |
January 4, 2023, 18:06 |
Moe
Rep Power: 5 |
Hey everyone,
I was trying to create an output variable in Fluent that will calculate the Physiological Equivalent Temperature. i will use it to create contours later I tried to use ChatGPT to get help as I don't have experience with coding I got the following code Code:
#include "udf.h" // Declare a global variable to store the physiological equivalent temperature real physiological_equivalent_temperature[THREAD_MAX][THREAD_MAX]; // Define a UDF to calculate the physiological equivalent temperature at each time step for all cells in the domain DEFINE_ON_DEMAND(calculate_physiological_equivalent_temperature_all) { int i, j; real air_temperature; // in Celsius real relative_humidity; // in % real wind_speed; // in m/s // Loop over all threads in the domain for (i = 0; i < THREAD_MAX; i++) { // Loop over all cells in the thread for (j = 0; j < THREAD_MAX; j++) { // Read the air temperature, relative humidity, and wind speed from the Fluent simulation air_temperature = C_T(cell_center, i, j); relative_humidity = C_HUMIDITY(cell_center, i, j); wind_speed = C_V(cell_center, i, j); // Calculate the physiological equivalent temperature using the formula: // PET = -2.7 + 0.66 * air_temperature + 0.39 * relative_humidity * (0.5 * air_temperature - 10.5) + 0.29 * wind_speed physiological_equivalent_temperature[i][j] = -2.7 + 0.66 * air_temperature + 0.39 * relative_humidity * (0.5 * air_temperature - 10.5) + 0.29 * wind_speed; } } } // Define a UDF to output the physiological equivalent temperature to a file for all cells in the domain DEFINE_DPM_OUTPUT_VAR(write_physiological_equivalent_temperature_all, f, t, i) { int i, j; // Loop over all threads in the domain for (i = 0; i < THREAD_MAX; i++) { // Loop over all cells in the thread for (j = 0; j < THREAD_MAX; j++) { // Write the value of the physiological equivalent temperature for the cell to the output file fprintf(f, "%f\n", physiological_equivalent_temperature[i][j]); } } } but from my understanding, this is not the correct way of creating c_loop Can anyone please help me fix this code? thanks in advance |
January 8, 2023, 14:37 |
Andrew
Rep Power: 3 |
First off, I'd recommend reading the fluent UDF manual if you haven't already. Even if you're not familiar with C/C++, it's got some good examples and describes the necessary functions very clearly. If you read up on some of the functions you're trying to use here, it will likely help you debug.
For example - the C_T macro should only take two arguments, not three. Also, in many cases, UDFs are unable to be used with 2D arrays (not sure why, I ran into this problem recently). In addition, writing the PET to an output file will not be done with a fprintf function (this prints to the console window). There are a few ways to do this; try reading about "user defined scalar" values and how to use them. Try taking a look at this link for an example of the define_on_demand function: https://www.afs.enea.it/project/nept...udf/node28.htm If you provide more details about error codes, it will help us help you as well. |
fluent, output, thermal comfort, udf, user defined |
UDF of saturation temperature | stanlee8 | Fluent UDF and Scheme Programming | 8 | June 27, 2021 07:12 |
Saturation temperature UDF for evaporation-condensation | obiscolly50 | Fluent UDF and Scheme Programming | 1 | June 20, 2021 10:08 |
Help with unsteady calculation with source/sink UDF | RobV | Fluent UDF and Scheme Programming | 3 | March 10, 2016 03:45 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Sequential calculation of Temperature and mass tra | J.W.Ryu | FLUENT | 7 | June 18, 2002 07:12 |
