Bypass "proceed after mesh manipulation" warning.
Old   December 30, 2022, 06:37
Default Bypass "proceed after mesh manipulation" warning.
Odisha
Siba11 is on a distinguished road
Hi everyone.
I'm trying to automate my fluent simulation using a scheme script. Apparently, for each button (or icon) that appears on the screen, there is a corresponding TUI command for it.
For instance, if you type the following command in the fluent console, it will start the calculation process:
(cx-gui-do cx-activate-item "Run Calculation*Table1*Table6(Solution Advancement)*Table1*PushButton1(Calculate)")
Alternatively, you can just mouse-click on the 'calculate' icon to start the calculation. So, coming to the actual problem: I have a simulation setup, where mesh cells will be separated and deactivated at each time step. The commands for separating the cells are :
(cx-gui-do cx-activate-item "Ribbon*Frame1*Frame2(Domain)*Table1*Table3(Zones)*PushButton2(Separate)")
(cx-gui-do cx-activate-item "MenuBar*PopupMenuSeparate*Cells...")
(cx-gui-do cx-activate-item "Separate Cell Zones*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "Warning*PanelButtons*PushButton1(OK)")
(cx-gui-do cx-activate-item "Separate Cell Zones*PanelButtons*PushButton2(Cancel)"))
However, as soon as I type in the 3rd line, a warning dialog box appears on the screen (image attached below), which requires manual intervention. I cannot find any TUI command for it, and this is preventing me from automating the process in its entirety.
Is there any way that I can bypass this warning, or maybe handle it through a TUI command that I can incorporate in my scheme script?
Thanks.
Siba11 is offline   Reply With Quote
Old   December 30, 2022, 12:20
Odisha
Originally Posted by Siba11 View Post
Hi everyone.
Thanks.
Hi, I found a solution to this problem.
Instead of typing in those 5 lines for performing cell separation, one can just use this command:
(ti-menu-load-string "/mesh/modify-zones/sep-cell-zone-mark fluid \"field_value_0\" yes c activate-all")
It will automatically separate the cells without showing any warning.
[swak4Foam] installation problem with version 0.2.3 Claudio87 OpenFOAM Community Contributions 9 May 8, 2013 11:20
[Gmsh] discretizer - gmshToFoam Andyjoe OpenFOAM Meshing & Mesh Conversion 13 March 14, 2012 05:35
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
