Find_Cell_With_Point does not work well on complex geometries?
Old   December 7, 2022, 02:40
Default Find_Cell_With_Point does not work well on complex geometries?
rephical is on a distinguished road
Hey all, I have a CSV file containing x,y,z points. I want to get those x,y,z points and then find the cell nearest to that point. I found that using Find_Cell_With_Point allows me to do that. Using that function on a simple geometry like a rectangle does not have any problems, but I'm having a lot of trouble when I use it on complex geometries. What could be the problem here? Here's my code:
#include <udf.h>
#include <cxndsearch.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
static ND_Search *domain_table = NULL;
DEFINE_ON_DEMAND(find_cells2)
        cell_t c;
        Thread *t;
        CX_Cell_Id *cx_cell;
        int cell_ID;
        real cVolume;
        real P[3];
        real P_Cell[3];
        FILE *fp;
        char line[1024];
        int rayID, side, prevID, nextID, surfID;
        double x,y,z;
        fp = fopen("udf_csv.csv","r");
        if(fp == NULL){
            printf("Trouble reading file\nAborting..");
            fclose(fp);
            abort();
        domain_table = CX_Start_ND_Point_Search(domain_table,TRUE,-1);
        while(fgets(line,1024,fp)){
            sscanf(line,"%d,%lg,%lg,%lg,%d,%d,%d,%d",&rayID,&x,&y,&z,&side,&prevID,&nextID,&surfID);
            P[0] = x;
            P[1] = y;
            P[2] = z;
            cx_cell = CX_Find_Cell_With_Point(domain_table,P,0.0);
            if(cx_cell){
                c = RP_CELL(cx_cell);
                t = RP_THREAD(cx_cell);
                cell_ID = C_ID(c,t);
                C_CENTROID(P_Cell,c,t);
                cVolume = C_VOLUME(c,t);
                Message("\n %d %g \t %g \t %g \t %g",cell_ID,P_Cell[0],P_Cell[1],P_Cell[2],cVolume);
            }else{
                Message("\nCannot find cell using point [%g,%g,%g]",P[0],P[1],P[2]);
        domain_table = CX_End_ND_Point_Search(domain_table);
        fclose(fp);
Here is my csv file:
2510,-0.184337,6.45695,0.191743,1,2509,0,3
2517,-0.00135845,6.08666,0.25398,1,2516,0,5
2521,-0.207771,6.04,0.0328325,1,2520,0,5
2524,0.184953,6.626,0.0102348,1,2523,0,4
2527,0.250984,6.07845,0.00956254,1,2526,0,5
2531,0.0969752,6.626,0.212096,1,2530,0,4
2534,-0.211653,6.04,-0.0855774,1,2533,0,5
2537,0.0661434,6.04,0.179724,1,2536,0,5
2543,0.147094,6.04,-0.126483,1,2542,2544,5
2552,-0.00681696,6.07177,-0.13546,1,2551,0,3
2555,0.0201342,6.04,0.200304,1,2554,0,5
2559,0.188615,6.04,-0.0341838,1,2558,0,5
2565,0.00556855,6.07901,0.135919,1,2564,0,3
2568,-0.0382014,6.0825,0.134891,1,2567,0,3
Here is my output:
Cannot find cell using point [-0.184337,6.45695,0.191743]
2907897 -0.00285511 	 6.08873 	 0.253857 	 1.19582e-08
2669898 -0.20529 	 6.04087 	 0.0322238 	 1.10349e-08
206464 0.184174 	 6.62675 	 0.0118884 	 1.24341e-08
2320551 0.250745 	 6.08027 	 0.00939368 	 1.30901e-08
213033 0.0964352 	 6.62675 	 0.213118 	 1.44972e-08
2455386 -0.211253 	 6.0408 	 -0.0856087 	 6.03395e-09
2481309 0.0666147 	 6.04097 	 0.180317 	 1.20944e-08
2484411 0.145721 	 6.0409 	 -0.127359 	 1.4037e-08
1817709 -0.00758865 	 6.0714 	 -0.134713 	 1.53618e-09
2618335 0.0231374 	 6.04087 	 0.201707 	 1.73295e-08
2482991 0.188002 	 6.041 	 -0.0346246 	 1.26253e-08
Cannot find cell using point [0.00556855,6.07901,0.135919]
1797769 -0.0381706 	 6.08214 	 0.133913 	 1.14033e-09
rephical is offline   Reply With Quote
Old   December 8, 2022, 02:25
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you've just said, that macro works fine on some geometries
probably, the problem is in your specific case
actually, the reason, why are you reading coordinates of cells from file is not clear
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
find cell, udf and programming
[Salome] problem with work flow: freeCAD => Salome => cfMesh mmohaqeqf OpenFOAM Meshing & Mesh Conversion 3 February 22, 2023 05:00
MultiRegion SnappyHexMesh Workflow for complex geometries Dicanic Main CFD Forum 3 March 3, 2022 19:18
First CFD consulting Job for wind turbine - What would be a good cost for my work? erickmartinez Main CFD Forum 0 May 8, 2021 20:32
[ANSYS Meshing] Meshing complex geometries Pavan07 ANSYS Meshing & Geometry 0 March 19, 2020 05:18
Complex FFT for real data Hisham Main CFD Forum 0 November 12, 2011 15:53
