Compile 6Dof-Rotary UDF code
Old   November 24, 2022, 07:11
Default Compile 6Dof-Rotary UDF code
bob
batuning is on a distinguished road
Dear friends ,
can you run my code .i want simply rotate a turbine with wind velocity .but my code no compile and error , my fluent and visual studio works and no problem for compiling codes .just this code no works .can you find a problem ?
my other question is how can achieve ab omega (w) angular velocity every time?
#include "udf.h"
#include "math.h"
DEFINE_SDOF_PROPERTIES(rotor, prop, dt, time, dtime)
prop[SDOF_MASS] = 0.218786; /*Mass of the rigid body in [kg] */
prop[SDOF_IZZ] = 0.000161; /*Mass moment of inertia about Z axis [kg/m^2]*/
/* Translational motion setting, use TRUE and FALSE as applicable */
prop[SDOF_ZERO_TRANS_X] = TRUE; /*Translation allowed in global X-Direction? */
prop[SDOF_ZERO_TRANS_Y] = TRUE; /*Translation allowed in global Y-Direction? */
prop[SDOF_ZERO_TRANS_Z] = TRUE; /*Translation allowed in global Z-Direction? */
/* Rotational motion setting, use TRUE and FALSE as applicable*/
prop[SDOF_ZERO_ROT_X] = TRUE; /*Rotation allowed about global X-Axis? */
prop[SDOF_ZERO_ROT_Y] = TRUE; /*Rotation allowed about global Y-Axis? */
prop[SDOF_ZERO_ROT_Z] = FALSE; /*Rotation allowed about global Z-Axis? */
/* DT_THETA(dt): orientation of body-fixed axis vector, DT_CG(dt): center of gravity vector, DT_VEL_CG(dt): cg velocity vector, DT_OMEGA_CG(t): angular velocity vector */
prop[SDOF_LOAD_M_Z] = -9.81 * sin(DT_THETA(dt)[2]) ;
Message("\n 2D: updated 6DOF properties DT_THETA_Z: %e, Mz: %e, Mass: %e \n",
DT_THETA(dt)[2], prop[SDOF_MASS]);
batuning is offline   Reply With Quote
Old   November 28, 2022, 20:16
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
code is correct except last line
Message("\n 2D: updated 6DOF properties DT_THETA_Z: %e, Mz: %e, Mass: %e \n",DT_THETA(dt)[2], prop[SDOF_LOAD_M_Z], prop[SDOF_MASS]);
however, it should not be a problem,
try it anyway
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 29, 2022, 03:46
bob
thanks .and can you tell me how i use (extract) omega (angular velocity ) for this code?
udf.c
i want move rotor and gate as wind power not as omega .
i should change omega (w) .and try put 6dof angular velocity
fluent - udf, udf compilation
UDF ansys fluent error that I ́m unable to identify, happens when I compile the UDF JuanReyes Fluent UDF and Scheme Programming 2 August 14, 2023 12:01
Urgent help for UDF Code needed force_95 FLUENT 2 October 25, 2019 08:35
Dumb Ansys Fluent can't compile UDF ordinary FLUENT 1 October 9, 2019 08:55
ATTN ALL: SOLUTON TO UDF COMPILE PROBLEM Rizwan Fluent UDF and Scheme Programming 40 March 18, 2018 07:05
compile the UDF Li Jingping FLUENT 2 April 14, 2003 22:18
