Help with the udf compiling
Old   November 23, 2022, 10:05
Default Help with the udf compiling
D20125511
D20125511 is on a distinguished road
Hello there,
I'm trying to perform a 2D axisymmetric simulation of a sessile droplet with a dynamic contact angle and wetting force model as a UDF. I'm quite new with udfs and getting a series of errors when I'm trying to compile my code in ANSYS Fluent v2021 R2 and the code is been written in Visual Studio 17.4.
UDF:
#include "udf.h"
#include "sg.h"
DEFINITION OF PRE - PROCESSING PARAMETERS
#define Psat_ref 12352 //REFERENCE SATURATION PRESSURE FOR THE CALCULTION OF CLAUSIUS-CLAPEYRON EQUATION
#define Tsat_ref 323.15 //REFERENCE SATURATION TEMPERATURE
#define Tref 298.15 //REFERENCE (AMBIENT) TEMEPRATURE - SIMULATING CONDITIONS
#define Dref 2.6e-5 //REFERENCE DIFFUSION FOR THE CALCUTION OF TEMPERATURE-DEPENDENT DIFFUSION COEFFICIENT
#define Mair 0.029 //MOLECULAR WEIGHT FOR AIR (kg/mol)
#define Mw 0.018 //MOLECULAR WEIGHT FOR WATER (kg/mol)
#define R 8.3145 //UNIVERSAL GAS CONSTANT (J/mol*K)
#define Hamb 0.45 //AMBIENT RELATIVE HUMIDITY
#define THC_w 4182 //THERMAL CAPACITY OF WATER (J/kg)
#define THC_v 1006 //THERMAL CAPACITY OF AIR (J/kg)
DEFINITION OF TEMPERATURE DEPENDENT MATERIALS PROPERTIES
DEFINE_PROPERTY(Saturation_temp, sfc, rho_w, ka_w, mu_w, hfg, P_sat, ka_v, mu_v, c, t)
t: mixture thread
c: cell variable
Cell Volume
real T_sat;
real vol = C_VOLUME(c, t);
Thread *pt = THREAD_SUB_THREAD(t, 0); //PRIMARY PHASE THREAD
Thread *st = THREAD_SUB_THREAD(t, 1); //SECONDARY PHASE THREAD
real vf_s = C_VOF(c, st); //IDENTITY OF SECONDARY PHASE BY CONSIDERING VOF CELLS
real vf_p = 1 - vf_s; //IDENTITY OF PRIMARY PHASE (1 - SECOUNDARY VOF CELLS)
real P_mixture = C_P(c, t); //DEFINITION OF MIXTURE PRESSURE (WATER VAPOR - AIR)
real P_operating = RP_Get_Real("operating-pressure"); //FOR GETTING THE OPERATING PRESSURE
real rho_p = C_R(c, pt); //PRIMARY PHASE DENSITY
real P_w; //CELL PRESSURE FOR WATER PHASE
if (vf_p == 1) //FOR SECONDARY PHASE ONLY
P_w = P_mixture + P_operating;
else
real m_sec = rho_p * vol * vf_p; //CALCULATION OF SECONDARY PHASE MASS
real m_wv = C_YI(c, pt, 0) * m_sec; //CALCULATION OF MASS OF WATER VAPOR WITHIN A CELL
real m_air = m_sec - m_wv; //CALCULATION OF MASS OF AIR WITHIN A CELL
real N_wv = m_wv / Mw; //CALCULATION OF TOTAL NUMBER OF MOLES OF WATER VAPOR
real N_air = m_air / Mair; //CALCULATION OF TOTAL NUMBER OF MOLES OF AIR
real N_total = N_wv + N_air; //CALCULATION OF TOTAL NUMBER OF MOLES OF COMPOUNDS
P_w = (C_P(c, t) + P_operating) * (N_wv / N_total); //CALCULATION OF PARTIAL VAPOR PRESSURE
T_sat = (1723.6425 / (8.05573 - ((double)log10((double)P_w / 133.322))) - 233.08) + 273.15; //FROM ANTOINE EQUATION - DESCRIBING THE RELATION BETWEEN VAPOR PRESSURE & TEMPERATURE FOR PURE SUBSTANCES
C_UDMI(c, t, 0) = T_sat;
if (T_sat < 273 || T_sat > 473)
Message("Temp %f\n", T_sat);
sfc = 0.0943 + 4.0e-6 * T_sat - 3.0e-7 * T_sat * T_sat; //TEMPERATURE-DEPENDENT SURFACE-TENSION (N/m)
rho_w = 753.09 + 1.8804 * T_sat - 0.0036 * T_sat * T_sat; //TEMPERATURE-DEPENDENT DENSITY OF WATER (kg/m3)
ka_w = -0.7513 + 0.0074 * T_sat - 1.0e-5 * T_sat * T_sat; //TEMPERATURE-DEPENDENT THERMAL CONDUCTIVITY OF WATER (W/m*K)
mu_w = 0.1104 - 0.0009 * T_sat + 3.0E-6 * T_sat * T_sat - 3.0E-9 * T_sat * T_sat * T_sat; //TEMPERATURE-DEPENDENT VISCOSITY OF WATER (Pa*s)
hfg = -3.4 6* T_sat * T_sat + 2.7554e6; //TEMPERATURE-DEPENDENT LATENT HEAT OF VAPORIZATION OF WATER (J/kg)
P_sat = -4.0E6 + 40702 * T_sat - 139.54 * T_sat * T_sat + 0.1599 * T_sat * T_sat * T_sat; //TEMPERATURE-DEPENDENT SATURATION PRESSURE (Pa)
ka_v = 8.0e-5 * T_sat - 0.0047; //TEMPERATURE-DEPENDENT THERMAL CONDUCTIVITY OF VAPOR (W/m*K)
mu_v = 3.0e-8 * T_sat - 1.0e-7; //TEMPERATURE-DEPENDENT DENSITY OF VAPOR (kg/m3)
return T_sat;
DEFINE ADJUST(dropadj, d)
int zone_ID = 12; //IDENTIFICATION OF WALL ZONE TO DEFINE CONTACT ANGLE
cell_t c;
cell_t c0;
Thread *t0, *tw, *ta;
face_t f;
real uCL, theta, Ca, t, x, y, source, vo, vol, fvo, x1[ND_ND];
double dynamiccangle;
int phase_domain_index = 1;
Thread *thread = Lookup_Thread(d, zone_ID);
begin_f_loop(f, thread)
c0 = F_C0(f, thread);
t0 = THREAD_T0(thread);
ta = THREAD_SUB_THREAD(t0, 0);
tw = THREAD_SUB_THREAD(t0, phase_domain_index);
uCL = C_U(c0, tw);
C_UDMI(c0, tw, 0) = uCL;
Ca = 0.001003 * uCL / 0.072;
vol = C_VOLUME(c0, t0);
C_CENTROID(x1, c0, to);
if (uCL > 0) //IMPLEMENTATION OF KISTLER'S LAW
theta = Ca + 0.326144; //arccos(0.326144) = 1.2385 rad = 70.96°
y = pow((theta / (1 + (1.31 * pow(theta, 0.99)))), 0.706) * 5.16;
t = tanh(y);
x = (1 - 2 * t);
dynamiccangle = acos(x) / 22 * 7 * 180;
if (C_VOF(c0, tw) > 0.05 && C_VOF(c0, tw) < 0.95)
source = 0.072 * (-0.951 - cos(dynamiccangle)) * x1[0] / vol; //DEFINITION OF WETTING FORCE MODEL
C_UDMI(c0, t0, 3) = source;
F_UDMI(f, thread, 2) = source;
C_UDMI(F_C0(f, thread), THREAD_TO(thread), 2) = F_UDMI(f, thread, 2);
else if (uCL < 0)
theta = Ca + 0.32626;
t = tanh(y);
x = (1 - 2 * t);
if (C_VOF(c0, tw) > 0.005 && C_VOF(c0, tw) < 0.99)
source = 0.072 * (-0.927 - cos(dynamiccangle)) * x1[0] / vol;
end_f_loop(f,thread)
DEFINITION OF OUTER BOUNDARY PROFILE BASED ON AMBIENT CONDITIONS & CONTACT ANGLE
DEFINE_PROFILE(Contant_Angle_Set_Profile, P_sat_amb, c, t)
face_t f; //DEFINITION OF CONTACT ANGLE PROFILE BOUNDARY CONDITION
begin_f_loop(f, t)
F_PROFILE(f, t, i) = F_UDMI(f, t, 2);
end_f_loop(f,t)
real P_sat_amb; //DEFINITION OF PROFILE BOUNDARY CONDITION FOR SATURATION PRESSURE
P_sat_amb = (double)P_w / Hamb;
return P_sat_amb;
DEFINITION OF SOURCE TERM FOR MOMENTUM EQUATION
DEFINE_SOURCE(xmom_source, c, t, ds, eqn)
real s = C_UDMI(c, t, 3);
ds[eqn] = 0;
return s;
List of Errors after compilation:
thermalpotential.c(30,46): error: too many arguments provided to function-like macro invocation
C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\ udf\udf.h(394,9): note: macro 'DEFINE_PROPERTY' defined here
#define DEFINE_PROPERTY(name, c, t) EXTERN_C real name(cell_t c, Thread *t)
thermalpotential.c(30,1): warning: type specifier missing, defaults to 'int' [-Wimplicit-int]
thermalpotential.c(30,16): error: expected ';' after top level declarator
thermalpotential.c(147,57): error: too many arguments provided to function-like macro invocation
C:\PROGRA~1\ANSYSI~1\v212\fluent\fluent21.2.0\src\ udf\udf.h(392,9): note: macro 'DEFINE_PROFILE' defined here
#define DEFINE_PROFILE(name, t, i) EXTERN_C void name(Thread *t, int i)
2 warnings and 3 errors generated.
After Loading the code
Error: The UDF library you are trying to load (libudf) is not compiled for parallel use on the current platform (win64).\n\nThe system cannot find the file specified.
\n\nD:\UDFS\libudf\win64\2ddp_host\libudf.dll
Error Object: #f
Please avail some suggestions so I can perform this task.
D20125511 is offline   Reply With Quote
Old   November 25, 2022, 08:39
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
remove sfc, rho_w, ka_w, mu_w, hfg, P_sat, ka_v, mu_v from header
definition of DEFINE_PROPERTY is following
DEFINE_PROPERTY(name,c,t)
read ansys fluent customization manual for more information
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 25, 2022, 09:09
D20125511
Hello Alexander,
I realized that and have defined the properties separately, however, now I'm having different errors:
1) In the definition of the profile for the contact angle set profile, I'm getting errors as the defined variable is not a pointer but an int and it shows in the following line
begin_f_loop(f, t)
2)Even if I ran only the defined properties segment alone then I'm getting an error as not able to find vof-air.
Apart from that after I'm getting issues with running the code in a parallel processor even after including #if !Parallel or # !RP_HOST line within the code. Could you please help me out with these issues?
Old   November 28, 2022, 19:46
Alexander
simplify your code and debug, late add functionality
best regards
dynamic contact angle, fluent, udf
UDF compiling error Weiqiang Liu FLUENT 2 November 21, 2018 10:36
UDF Compiling / Parallel mode MV78 Fluent UDF and Scheme Programming 6 May 29, 2018 06:02
ERROR in compiling UDF stefanos Fluent UDF and Scheme Programming 1 April 25, 2012 08:37
udf compiling problem akr FLUENT 3 August 22, 2007 08:14
On Compiling a UDF David Chabot FLUENT 5 May 20, 2005 10:13
