Floating point exception error
Old   November 5, 2022, 23:27
Post Floating point exception error
bilal
hbilal1076 is on a distinguished road
Please senior help me to resolve the shown error.
I will highly appreciate your help.
when I compile UDF and then click calculate, after 772 iteration it give the following error.
Divergence detected in AMG solver: enthalpy
Minimum PDF table enthalpy exceeded in 325733 cells on zone 2.
Maximum PDF table enthalpy exceeded in 17 cells on zone 2.
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 268951 cells
Error at host: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
Error: floating point exception
Error Object: #f
Calculation complete.
I have thesis submission in a week, please do favour and help me in solving this error. TIA
hbilal1076 is offline   Reply With Quote
Old   November 6, 2022, 23:56
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
solution is diverged
there are several possible reasons for that:
1. UDF
2. Your case settings
3. Mesh quality
run simulation without UDF to check your settings and mesh quality
next run case with simplified UDF, clarify that it works
run everything -> now you know for sure that the problem is in UDF
you may share your UDF here, so users can check if everything is ok
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   November 7, 2022, 00:35
Default Mesh quality and UDF
bilal
Dear Prof. Alexander,
My mesh quality is fine and there is no problem in my UDF. I am using nonpremixed combusion using coupled method, I am using UDF of WSGG radiation model to find the radiation influent on species and soot, I did one change and it's now working, I just changed K-Epsilon model from standard to realizable, however, I don't, know, if this change is correct or not?
@alexanderz
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 10:00
Undeclared Identifier Errof UDF SteveGoat Fluent UDF and Scheme Programming 7 October 15, 2014 08:11
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
[Gmsh] Gmsh and samplesurface touf OpenFOAM Meshing & Mesh Conversion 2 December 10, 2007 03:27
