Define liquid state property using UDRGM(User Defined Real Gas Model) |
October 27, 2022, 03:06 |
Rep Power: 4 |
Hello
I'm trying to define liquid property to my simulation that changed temperature and pressure using UDRGM(User-Defined Real Gas Model) in FLUENT. I read manual and made a code on C++. And code equipped well in FLUENT. When I set vapor phase, FLUENT calculated vapor state property. But in liquid state, all residuals went divergence and didn't calculate anymore. In first time, I thought that I typed wrong code, but there were no significance error in code. Also, I thought that calculation equations had some problem, but in MATLAB, it could calculate property in liquid state. And someone told me that difficulties in code could affect divergence, So I changed the code simpler, but it didn't work. At lastly, in FLUENT manual, it can set cell zone state. So, I set the cell zone vapor to liquid. Also, it didn't work. I searched many times in CFD online and another CFD community, there were no appropriate information related my problem. And most of the user used UDRGM to define vapor state properties. I think that I tried all that I have to do it... So, If someone who tried or defined liquid phase using UDRGM, I want to know how did it. Thank you |
November 3, 2022, 00:06 |
Alexander
Rep Power: 34 |
did you check could you simulate your case file with ideal gas?
show your simplified code
best regards ****************************** press LIKE if this message was helpful |
liquid property, property udf, udrgm |
Problem with using User Define Real Gas Model (UDRGM) | Amirreza_pro | Fluent UDF and Scheme Programming | 6 | July 1, 2021 22:57 |
Simulation of a single bubble with a VOF-method | Suzzn | CFX | 21 | January 29, 2018 01:58 |
Laminar Kinetic Energy Model (Walters 2008) | logoswort | Fluent UDF and Scheme Programming | 2 | May 19, 2017 20:41 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
Two-Phase Buoyant Flow Issue | Miguel Baritto | CFX | 4 | August 31, 2006 13:02 |
