Incompressible Ideal Gas UDF
Old   October 24, 2022, 14:37
Default Incompressible Ideal Gas UDF
inscrutable is on a distinguished road
Hi all,
How do you define a different operating pressure for different outlets If an incompressible ideal gas law is used.
My geometry model contains 2 inlets and 2 outlets and each have different fluid.
I'd like to calculate the rho based on the local temperature. I can't use a fixed operating pressure.
Since rho= P_OP/(R/M)*T
I'd like to write a function/expression/UDF to describe:
IF fluid is Water then > the operating pressure is 1 bar
IF fluid is Air then> the operating pressure is 2 bar.
Is this possible?
Any help would be really appreciated!
inscrutable is offline   Reply With Quote
Old   October 24, 2022, 15:39
Hi guys I made an expression as follows it seems to be right! but Im open to other methods.
(100 [Pa])/ (((R /28.996 [kg/kmol])) *StaticTemperature)
Best
Old   October 26, 2022, 02:54
Neel
neelcfd is on a distinguished road
There's a option of using Incompressible Ideal Gas equation in material property. Make sure you have energy equation on. The density of fluid with only vary with the temperature.
neelcfd is offline   Reply With Quote
Natural Convection ! Boussinesq Vs Ideal Gas density cfd_user_pune ANSYS 4 September 15, 2020 09:46
Energy equation - Incompressible Ideal Gas? Wingman ANSYS 3 April 9, 2017 01:49
Density and compressiblity Mohsin FLUENT 7 June 7, 2015 23:23
Ideal gas problem Atze CFX 12 March 20, 2014 16:56
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
