How to extract Boundary information in a Journal or a text file
Old   October 10, 2022, 06:35
Default How to extract Boundary information in a Journal or a text file
Malyk is on a distinguished road
Hello every one,
Could you help me to do an extraction of boundary informations. For exemple, I am working on a very complex geometry and I put several boundary condition for various scalar and i would like to write a journal in order to summarize all apllied conditions on all face ID.
I now how to do a loop on the ID but I don t know how to extract the applied boudary conditions (for example: null flux for temperature, etc...)
I want to do this in order to have an overview of what I apllied and where... before lunch 6month of calculations...
Thanks for your helps.
Malyk is offline   Reply With Quote
Old   October 11, 2022, 00:46
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
in fluent console write
file write-settings filename
press enter
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   October 11, 2022, 07:19
Thanks for your answer.
Your response helps me a lot. It is not so easy to well understand what is the correspondance between the value [0 1 2 etc] and the specified value, flux etc.. for each line and option in this huge file but all informations I need are contained inside.
I need to do a deep and hard work in order to clarify this but thanks a lot for you help. Very helpful for me.
Regards
Malyk
Old   October 11, 2022, 09:33
Does any one know how to extract only BC information and not all the settings. The file is very heavy...
I found file->write-bc and file->write-settings but they do the same things.
There is a lot of non usefull informations in the file and it could be simple for me if there is some one who already to the job
Regards
[Other] Tabulated thermophysicalProperties library chriss85 OpenFOAM Community Contributions 62 October 2, 2022 04:50
what is swap4foam ?? AB08 OpenFOAM 28 February 2, 2016 02:22
centOS 5.6 : paraFoam not working yossi OpenFOAM Installation 2 October 9, 2013 02:41
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 12:44
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
