How to control heat flux at fluid-solid interface to simulate drying
Old   October 9, 2022, 08:02
Default How to control heat flux at fluid-solid interface to simulate drying
UMIE is on a distinguished road
Good day,
I am trying to control the heat flux at a fluid-solid interface.
Inlet Conditions:
  • Velocity = 4 m/s
  • Temperature 353 K
Fluid-solid interface Initial Condition:
  • Initial Solid temp = 300 K
I would like to have air flow over solid and transfer heat to solid using coupling until interface reaches 320 K. When it reaches 320K I would like to stop any more heat from being transferred to solid for a certain amount of time. After that time is reached I want to continue transferring heat from 353K air to the solid using coupling. How do I do this?
I read that DEFINE_HEAT_FLUX should only be used for external walls and not internal walls. Which udf macro can i use to do this?
UMIE is offline   Reply With Quote
My radial inflow turbine Abo Anas CFX 27 May 11, 2018 02:44
Centrifugal fan-reverse flow in outlet lesds to a mass in flow field xiexing CFX 3 March 29, 2017 11:00
Heat Flux at Internal walls or Fluid Solid Interface Mahi CFX 3 October 1, 2012 03:18
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 16:55
