Determine Max Velocity within 2 inches of Surface |
September 21, 2022, 21:35 |
Chris N.
Rep Power: 4 |
I wrote a UDF to return the maximum velocity within 2 inches of a specified surface. To accomplish this, I defined a cell register to get all cells within 2 inches of that specified surface. I then used the register to separate out a new cell zone. The UDF loops over all cells within that new cell zone and returns the max velocity and cell centroid of where the max velocity occurs. I separated out the new cell zone for two reasons: 1) to reduce the number of cells to loop through and 2) to limit the cells to the surface of interest (ie, I wanted to exclude all other surfaces/walls other than the one I am interested in). Without separating out the cell zone, I would have had to loop over all cells in the entire domain and all face cells of the surface of interest to determine if the volume cell was within 2 inches.
I believe the above can be accomplished via expressions. However, I believe I can only return the maximum velocity within the cell register and not the location of that velocity using expressions. Is there a way to accomplish the whole UDF (ie, find max velocity and location within 2 inches of desired surface) using expressions? Is there a better was to accomplish this via UDF? Is there a function that will calculate the distance between a face zone ID and cell or does that have to be programmed manually as described above (ie, looping over all cells and face cells)? Can you give C_WALL_DIST(c,cell_thread) a face_thread instead of a cell_thread, where the face_thread would be the id a wall? |
expression, udf |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 14:48 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 03:53 |
[snappyHexMesh] Layers don't fully surround surface | EVBUCF | OpenFOAM Meshing & Mesh Conversion | 14 | August 20, 2012 05:31 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 22:14 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 19:07 |
