September 14, 2022, 01:56 |
2-dimensional tail gate in ansys fluent
SUBHAM
Rep Power: 5 |
Hi!!
I am simulating hydraulic jump in a 2-d rectangular flume(channel). The channel has inlet at left and a tailgate at right. I want the tail-gate to be vertically raised or lowered at : some specified rate , upto some specified height ,during calculations. In other words, while the flow is being calculated , I wish to raise the tail-gate i.e I want the boundary condition at the tail-gate to gradually change from "wall" to "pressure-outlet" at some rate. Also I may want to lower the tail-gate i.e change the boundary back from "pressure-outlet" to "wall". Can you please provide me an UDF / scheme to do this. I am totally ignorant about Coding. |
September 14, 2022, 04:10 |
Alexander
Rep Power: 34 |
I don't think thre is a way to make it directly, you can't change just a part of boundary from one typ to another:
1. you may split intle/outlet to several inlets/outlets and change some of them to other BC type under your conditions 2. you may try to use porous materials near by inlet/outlet (don't have experience on it) porosity 0 - no flow, porosity 1 - fully opened pass
best regards ****************************** press LIKE if this message was helpful |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 03:48 |
[ANSYS Meshing] How do I open a mesh made in Ansys Fluent 2020 R2 on Ansys Fluent 2019 R3? | Ryan T | ANSYS Meshing & Geometry | 3 | November 3, 2021 16:44 |
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro | cheezum | Hardware | 0 | February 28, 2017 11:23 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 13:07 |
error in opening fluent in ansys workbench | tmeysam92 | ANSYS | 3 | March 12, 2013 07:10 |
