September 11, 2022, 12:12 |
UDF reads CO at an outlet
AH
Is there an example of a UDF which reads CO at an outlet boundary? Looking for a way to read CO at two different time intervals, starting with something below, and if I can use these macros;
Initially inlet_1 = 10, inlet _2 = 0. If (C_YI(c,t,i) > C_YI_M2(c,t,i)) (Increment inlet_1 by 1e-3) && ( decrement inlet_2 by 1e-3) Just for starters, code below needs to read outlet via an a boundary ID, and then increment/decrement mass flows at inlet_1 and inlet_2. Thanks. int main () { real inlet_1, inlet_2; //the two inlets. Inlet_1=10 //starting with a value of 10. Inlet_2=0 //starting with a value of 0. begin_f_loop(f, t) //start looping { If(C_YI(c,t,i) > C_YI_M2(c,t,i)) //the two 1st macro reads at current time, 2nd reads at 2 time steps behind. BUT I don't know how to get C_YI(c,t,i) macro to get CO (carbon monoxide)at the outlet.// Inlet_1 +=1; //increment by 1 based on if condition. Inlet_2 -=1; //decrement by 1 based on if condition. Else if(C_YI(c,t,i) < C_YI_M2(c,t,i)) //this does the opposite to the above 'if' condition. Inlet_1 -=1; Inlet_2 +=1; //if either way changes in CO value are within 5% (0.05), then leave & print inlets as they are. Else ( ((C_YI(c,t,i))/( C_YI_M2(c,t,i)))<0.05 || ((C_YI_M2(c,t,i))/( C_YI (c,t,i)))<0.05 ) Message("RECOMMENDED value for inlet_1 within +/- 0.05 is: %g\n", inlet_1); Message("RECOMMENDED value for inlet_1 within +/- 0.05 is: %g\n", inlet_2); } end_f_loop(f,t) } Last edited by visitor; September 11, 2022 at 17:00. |
UDF for zero pressure gradient at BC outlet | ghordog | Fluent UDF and Scheme Programming | 1 | April 28, 2022 06:12 |
UDF writes the outlet temperature assignment to the inlet temperature of another calc | ZengJiChuan | FLUENT | 7 | May 27, 2020 05:14 |
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions | Vishnu_bharathi | CFX | 12 | November 21, 2017 07:56 |
UDF for flow at the outlet of pipe | sknandwani80@gmail.com | Fluent UDF and Scheme Programming | 0 | November 4, 2017 04:06 |
UDF in Fluent to Match Mass Flow at Pressure Outlet | Jonas Larsson | Main CFD Forum | 1 | April 29, 1999 11:44 |
