Appropriate Defined Macro for Surface Reactions on Particle Wall and Deposition |
September 11, 2022, 01:53 |
Rep Power: 5 |
Can anyone please provide help for this problem. What are appropriate predefined macros for the following: 1. An injected dpm particle with an initial surface site density needs to follow the following reaction: Cs-H + H => Cs-* + H2 Initial site surface density of particle is Cs-H (The will be predefined in kmol/m2). H and H2 are from the continuous phase. Site density of particle after reaction will include Cs-*. 2. A surface reaction which includes deposition on the particle. Cs-* + C2H2 => Cs-H + H2 + 2C 2C are the deposited carbon and should have a site density of Cs-* How can I update the particle size after the deposition? Note that the initially injected particles were based on the nucleation rate of a reaction in the continuous phase. Thanks |
particle deposition (wall adhesion) in discrete phase modeling by ansys fluent | iman77 | Fluent Multiphase | 0 | June 27, 2022 09:45 |
Deposition Rate and Wall Shear | zacko | CFX | 0 | January 27, 2020 10:35 |
UDF for DPM particle deposition modelingpa | haghshenasfard | Fluent UDF and Scheme Programming | 10 | September 15, 2019 03:03 |
particle does not stop | YANNAPOL | Fluent UDF and Scheme Programming | 2 | June 13, 2015 01:28 |
distance between particle and wall | Worth | FLUENT | 2 | June 13, 2009 04:04 |
