Node 999999: Process 28016: Received signal SIGSEGV |
August 28, 2022, 04:53 |
Amin
Rep Power: 5 |
Hi everyone,
I am simulating two phase flow, and I use UDF for boundary condition. The UDF contains "Define profile" and "Define execute at end" macros. There are two versions of Fluent on my computer, 19.2 and 2022, and their directory(installation drive) are the same. The UDF worked well for 19.2 version, but when I ran it on 2022 version, the following error occurred: Node 999999: Process 28016: Received signal SIGSEGV. ================================================== ============================ The fl process could not be started. ---------------------------------------------------- In documentation is said if you don't delete previous version, the directory of src/udf would not create, which is the case for me. For newer version, the directory didn't create. Could be this the cause? If yes, Should I delete previous version, and then reinstall new one? Also, I couldn't run the UDF in parallel in either version. I compiled it as interpreted. What is the cause? How Can I solve it? If I use compiled option, could it be helpful? Last edited by maba; August 28, 2022 at 16:01. |
August 28, 2022, 11:32 |
#2 | |
Ying Feng
Rep Power: 4 |
i had the problem when i began to learn UDF. The problem disappeared until i checked the UDF and modified something wrong. I suggest that you may check whether the UDF is right. |
August 28, 2022, 15:59 |
Amin
Rep Power: 5 |
Did you have the same problem? I don't think the udf has a problem. Because it works well in old version.
August 29, 2022, 04:53 |
Alexander
Rep Power: 34 |
compile udf, show log
best regards ****************************** press LIKE if this message was helpful |
September 1, 2022, 16:23 |
Amin
Rep Power: 5 |
There's no error, when I compile the udf. The error occurs, when I run the simulation.
What do you mean by log? you mean text in console tab in fluent? Or another file? cpp -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/main" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/addon-wrapper" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/io" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/species" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/pbns" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/numerics" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/sphysics" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/storage" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/mphase" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/bc" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/models" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/material" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/amg" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/util" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/mesh" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/udf" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/ht" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/dx" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/turbulence" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/acoustics" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/parallel" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/etc" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/ue" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/dpm" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/src/dbns" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/tgrid/src" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/cortex/src" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/client/src" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/multiport/src" -I"D:\Program Files\ANSYS Inc\v221\fluent\fluent22.1.0/../include" -I. -DUDFCONFIG_H="<C:/Users/mab12/AppData/Local/Temp/udfconfig-5256-node0.h>" "C:/Users/mab12/AppData/Local/Temp/FlowrateAdjusttwo.c.5256.0.c" |
September 4, 2022, 06:36 |
Amin
Rep Power: 5 |
Do you mean this file?
Node 999999 Fatal signal raised sig = Segmentation fault 44648430 CX_Primitive_Error fe350cc0 seh_filter_exe 446e8150 logical_right_shift eb9bec30 _C_specific_handler c92180 _chkstk c41020 RtlRaiseException c90da0 KiUserExceptionDispatcher 43b40130 init_cell_vector 446e8150 logical_right_shift 429aaa90 fluent_fprintf 446d3610 eval 446d3610 eval 446d3610 eval 446d3610 eval 446d4c70 set_cc 446d5420 eval_errprotect 446d3610 eval 446d3610 eval 446d3610 eval 446d3610 eval 446d4c70 set_cc 446d5420 eval_errprotect 44649390 CX_Interpret_String 42a20820 rpgetvar_errprotect 446e8150 logical_right_shift ff2f7020 BaseThreadInitThunk c42630 RtlUserThreadStart Error [node 999999] [time 9/4/22 14:2:24] Abnormal Exit! |
September 6, 2022, 03:41 |
#7 | |
Alexander
Rep Power: 34 |
once you click build in FLUENT GUI you have some text in console, I need that text.
information you've showewd is not full, doesn't show anything, actually Quote:
check if you allocated uaser define memomy locations. next time show your code, to save time of people who a re trying to gess, whats wong with your case
fluent, two phase problem, udf |
Using TUI to create velocity report definitions | RobR_CFD | FLUENT | 18 | August 12, 2022 20:19 |
Parallelization of a self-compiled boundary condition | dalasrevo | OpenFOAM Programming & Development | 4 | August 2, 2022 15:16 |
How do I change the serial udf to parallel? | dhdh89 | Fluent UDF and Scheme Programming | 14 | June 4, 2020 10:04 |
Process xxxx: received signal SIGSEGV; The fl process could not be started | Someeee | FLUENT | 1 | October 31, 2018 05:32 |
999999 (../../src/mpsystem.c@1123):mpt_read: failed:errno = 11 | UDS_rambler | FLUENT | 2 | November 22, 2011 10:46 |
