How looping over cells works in FLUENT UDFs?
Old   August 10, 2022, 03:12
Default How looping over cells works in FLUENT UDFs?
Cooper24 is on a distinguished road
I just have a simple 2D domain consisting of uniform hexahedral cells as shown in the attached image. I want to know the looping pattern in which looping over the cells happens. I have a total of 11232 cells. As I have understood, the cell index c is a number assigned to the cells and therefore there should be a total of 11232 values for c. Is there a way to know how begin_c_loop and end_c_loop works over the domain and in what order the looping over the cells works? I want to loop over the cells in a particular direction(say y, along each column). Can someone please help? Thanks in advance.
Cooper24 is offline   Reply With Quote
Old   August 10, 2022, 04:21
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
you may check it using udmi
put inside cell loop
C_UDMI(c,t,0) = k;
k+=1;
then plot udmi_0
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   August 10, 2022, 06:17
Thanks for your reply Alexander. I read and found that if I am using multiple cores, then the domain is divided into a number of partitions each having its own looping pattern. To get the idea, I need to see UDFs in parallel. Hope I am right.
cell count, loop meshing
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 09:26
Running UDF with Supercomputer roi247 FLUENT 4 October 15, 2015 14:41
looping over selected / marked cells Jonathan Fluent UDF and Scheme Programming 0 November 22, 2012 05:59
pushback function for vectors in Fluent UDFs ScottN Fluent UDF and Scheme Programming 0 January 31, 2011 10:20
[snappyHexMesh] snappyHexMesh aborting Tobi OpenFOAM Meshing & Mesh Conversion 0 November 10, 2010 04:23
