Expression conditional statement in Fluent
Like Tree2Likes
Old   September 4, 2022, 06:37
AH
visitor is on a distinguished road
Managed to get this scheme code going, no errors when compiled with Fluent, but when run got this error message after every time step! What could have gone wrong?
(Two_BC_type_Changes)
Error: eval: unbound variable
Error Object: two_bc_type_changes
(define (Two_BC_type_Changes)
(define time-sequence #(0 (30*8.333e-5) (310*8.333e-5))) ;begins opennings then close for compress and ignition finall opening with specific times
(define type-sequence #(2 1 2))
(define flag 0)
(define bctype 0)
(define time (rpgetvar ‘flow-time))
(define dt (rpgetvar ‘physical-time-step))
(set! flag 0)
(set! bctype 0)
(do ((i 0 (+ i 1)))
((= i (vector-length time-sequence)))
(if (>= time (- (vector-ref time-sequence i) (* 8.333e-5 dt)))
(if (<= time (+ (vector-ref time-sequence i) (* 8.333e-5 dt)))
(set! flag 1)
(set! bctype (vector-ref type-sequence i))
(if (= 1 bctype)
(if (= flag 1)
(set! flag 2)))
(if (= flag 1)
(begin
(ti-menu-load-string (format #f “define bou zone type 24 wall”))
(ti-menu-load-string (format #f “define bou zone type 23 wall”))
(ti-menu-load-string (format #f “define bou zone type 11 wall”))
(ti-menu-load-string (format #f “define bou zone type 12 wall”))
(if (= flag 2)
(cond
(and (> (rpgetvar ‘flow-time) 0.0) (< (rpgetvar ‘flow-time) (30*8.333e-5))) ;suction open big timer
(begin
(ti-menu-load-string (format #f “define bou zone type 24 pressure-inlet”))) ;suction open big BC status
(and (> (rpgetvar ‘flow-time) 0.0) (< (rpgetvar ‘flow-time) (30*8.333e-5))) ;suction open timer
(begin
(ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 24 yes no 1.1e5 no 1 no 300 no yes”))) ;suction open big pressure on
(and (> (rpgetvar ‘flow-time) 0.0050) (< (rpgetvar ‘flow-time) (30*8.333e-5))) ;suction open small timer
(begin
(ti-menu-load-string (format #f “define bou zone type 23 pressure-inlet”))) ;suction open small BC status
(begin
(ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 23 yes no 1.1e5 no 1 no 300 no yes”))) ;suction open small pressure on
(and (> (rpgetvar ‘flow-time) (490*0.000104)) (<= (rpgetvar ‘flow-time) (720*8.333e-5))) ;outlet open big timer
(begin
(ti-menu-load-string (format #f “define bou zone type 11 pressure-outlet”))) ;outlet open big BC status
(and (> (rpgetvar ‘flow-time) (490*0.000104)) (<= (rpgetvar ‘flow-time) (720*8.333e-5))) ;outlet open small timer
(begin
(ti-menu-load-string (format #f “define bou zone type 12 pressure-outlet”))) ;outlet open big BC status
(newline)
(if (= flag 1) (display “Exhaust BC now wall”))
(if (= flag 2) (Display “Exhaust BC now pressure inlet”))
visitor is offline   Reply With Quote
Old   September 4, 2022, 07:30
AH
Latest scheme error when run with fluent.
At every time step I get this message.
Error: Object: flow-time
Old   September 5, 2022, 03:56
AH
Then I tried to simplify this and get rid of the flags and loops, by using the following scheme code, but keep getting this error??
Error Object: �flow-time
(define (change_BC_cond_only)
(cond (>=(rpgetvar ‘flow-time) 0)
(ti-menu-load-string “define/boundary-conditions/zone-type 24 pressure-inlet”))
(ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 24 yes no 1.2e5 no 1 no 360 no yes”))
(>=(rpgetvar ‘flow-time) 0.00312)
(ti-menu-load-string “define/boundary-conditions/zone-type 24 wall”))
(<=(rpgetvar ‘flow-time) 0.03224)
(ti-menu-load-string “define/boundary-conditions/zone-type 11 wall”))
(else (>=(rpgetvar ‘flow-time) 0.03224)
(ti-menu-load-string “define/boundary-conditions/zone-type 11 pressure-outlet”)))
Old   September 6, 2022, 03:35
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
problem is in brackets, as it was in other versions of code (above)
stick to scheme language syntax
example
(cond
   ((positive? -5) (error "doesn't get here"))
   ((zero? -5) (error "doesn't get here, either"))
   ((positive? 5) 'here))
answer
here
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   September 6, 2022, 04:18
AH
Thanks Alex. I though it was the brackets, I will try this again. Meanwhile I run this code with one BC change relying on flag 1 and flag 2, rather than the complxity of the cond statement. The problem is the limitation of the two flags, it will be good if this can be modified with for example three or four flags (flag 1, flag 2, flag 3, flag 4..) The top part of the program loops over the flags. Still though no BC change was observed, but at least no errors.
(define (outlet_BC_type_Changes)
(define time-sequence #(0 0.05616)) ;begins opennings then close for compress and ignition finall opening with specific times
(define type-sequence #(1 2))
(define flag 0)
(define bctype 0)
(set! flag 0)
(set! bctype 0)
(do ((i 0 (+ i 1)))
(set! flag 1)
(if (= 1 bctype)
(if (= flag 1)
(set! flag 2)))
(if (= flag 1)
(begin
(if (= flag 2)
(begin
(ti-menu-load-string (format #f “define bou zone type 11 pressure-outlet”)) ;suction open big BC status
(ti-menu-load-string (format #f “define bou zone type 12 pressure-outlet”)) ;outlet open big BC status
Old   September 6, 2022, 04:48
AH
Just wrote this and got this error message, brackets!
Error: eof inside list
Error Object: ()
(define time-sequence #(0 0.00312 0.05616))
(define flag 0)
(define bctype 0)
(set! flag 0)
(set! bctype 0)
(do ((i 0 (+ i 1)))
(set! flag 1)
(if (= 1 bctype)
(if (= flag 1)
(set! flag 2)))
(if (= flag 1)
(begin
(ti-menu-load-string (format #f “define bou zone type 6 wall”))
(if (= flag 2)
(cond
((> (rpgetvar ‘flow-time) 0.0) (ti-menu-load-string (format #f “define bou zone type 24 pressure-inlet”))
((> (rpgetvar ‘flow-time) 0.0) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 24 yes no 1.1e5 no 1 no 300 no yes”))
((> (rpgetvar ‘flow-time) 0.0) (ti-menu-load-string (format #f “define bou zone type 23 pressure-inlet”))
((> (rpgetvar ‘flow-time) 0.0) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 23 yes no 1.1e5 no 1 no 300 no yes”))
((> (rpgetvar ‘flow-time) 0.05616) (ti-menu-load-string (format #f “define bou zone type 11 pressure-outlet”))
((> (rpgetvar ‘flow-time) 0.05616) (ti-menu-load-string (format #f “define bou zone type 12 pressure-outlet”))
Old   September 6, 2022, 20:23
Alexander
I recommend you to use notepad++, its quite comfortable, it will help you to check your brackets
best regards
Old   September 7, 2022, 02:50
AH
Thanks Alex. I will look at this tool, but looking at the first 22 lines of scheme code, what should change to make the code work with a third or even fourth flag. Right now it just works for two flags, flag 1 and flag 2. Thanks again
Old   September 7, 2022, 08:45
AH
Thanks Alex, downloaded Notepad++, yes it is helpful, had an extra bracket at the end.! Still if there is a way in increasing flags from 2 to 3 or even 4, it will be neater I think, no need for 'if' 'and' 'cond' ...
Old   September 7, 2022, 16:16
AH
This is what I am aiming for now to simplify the code and just change BCs based on flag 1, flag 2 and flag 3. I have not run this yet, though did check this with notepad++, and no bracket errors showed, still doesn't seem right.
(define type-sequence #(2 1 3))
(define flag 0)
(define bctype 0)
(set! flag 0)
(set! bctype 0)
(do ((i 0 (+ i 1)))
(set! flag 1)
(if (= 1 bctype)
(if (= flag 1)
(set! flag 2)))
(if (= flag 1)
(begin
(if (= flag 2)
(cond
(if (= flag 3)
(cond
UDF switching with a conditional statement visitor FLUENT 15 July 5, 2019 13:28
Ansys Fluent 17.0 Expression u_k FLUENT 8 May 13, 2019 07:15
Surface tension force expression at the wall in fluent IndrajitW FLUENT 0 April 15, 2013 09:37
Conditional statement over the entire mesh xisto OpenFOAM Programming & Development 6 November 24, 2010 13:13
CFX Expression Statement Ivan CFX 3 June 5, 2006 12:42
