#21 |
AH
Rep Power: 0 ![]() |
Thanks Alex. Z 👍
#22 |
AH
I originally wanted valve wall movement using UDF, but didn't work because of parse errors. Then tried UDF to switch boundary flow in x y z directions between 0 and 1, to stop/allow flow, didn't work.
Thanks, this seems to work, using scheme. |
#23 |
AH
Also Alex, I am trying this now, controlling to BCs, in one file code.
(define (outlet_BC_type_Change) (define time-sequence #(0.0 0.0374)) (define type-sequence #(1 2)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) (if (= flag 1) (ti-menu-load-string (format #f “define bou zone type 7 wall”))) (if (= flag 2) (ti-menu-load-string (format #f “define bou zone type 7 pressure-outlet”)) )) (newline) (if (= flag 1) (display “Exhaust BC now wall”)) (if (= flag 2) (Display “Exhaust BC now pressure outlet”)) ) (define (inlet_BC_type_Change) (define time-sequence #(0 0.0052)) (define type-sequence #(2 1)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) (if (= flag 1) (ti-menu-load-string (format #f “define bou zone type 6 wall”))) (if (= flag 2) (ti-menu-load-string (format #f “define bou zone type 6 pressure-inlet”) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 6 yes no 1.1e5 no 1 no 400 no yes”)) )) (newline) (if (= flag 1) (display “Exhaust BC now wall”)) (if (= flag 2) (Display “Exhaust BC now pressure inlet”)) ) |
#24 |
Alexander
Rep Power: 34 ![]() ![]() |
as you defining flag and bctype variable twice in your code, it could lead to problem
best regards ****************************** press LIKE if this message was helpful |
#25 |
AH
Alright, so I could the first part as it is, but the second part will be changed through out; -
(define flag_second 0) (define bctype_second 0) Thanks, but it did look ok when run, maybe because the two different parts are pulled under different calculation activities. |
#26 |
AH
Dear Alex.
Worked alright with yesterday's 22.08.2022, 13:22 posting, but now when I made the following changes in the second part, I got this error message "Error: eval: unbound variable Error Object: flag" Changes made in the second part to distinguish flag & bctype, from what is shown in the first part. In second part now showing: " (define flag_second 0) (define bctype_second 0) " I think I should leave it as it was before, because when defining commands, command-1 and command-2, the two parts are executed separately. (define (outlet_BC_type_Change) (define time-sequence #(0.0 0.0374)) (define type-sequence #(1 2)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) (if (= flag 1) (ti-menu-load-string (format #f “define bou zone type 7 wall”))) (if (= flag 2) (ti-menu-load-string (format #f “define bou zone type 7 pressure-outlet”)) )) (newline) (if (= flag 1) (display “Exhaust BC now wall”)) (if (= flag 2) (Display “Exhaust BC now pressure outlet”)) ) (define (inlet_BC_type_Change) (define time-sequence #(0 0.0052)) (define type-sequence #(2 1)) (define flag_second 0) (define bctype_second 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag_second 0) (set! bctype_second 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag_second 1) (set! bctype_second (vector-ref type-sequence i)) ))) (if (= 1 bctype_second) (if (= flag_second 1) (set! flag_second 2))) (if (= flag_second 1) (ti-menu-load-string (format #f “define bou zone type 6 wall”))) (if (= flag_second 2) (ti-menu-load-string (format #f “define bou zone type 6 pressure-inlet”) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 6 yes no 1.1e5 no 1 no 400 no yes”)) )) (newline) (if (= flag_second 1) (display “Exhaust BC now wall”)) (if (= flag_second 2) (Display “Exhaust BC now pressure inlet”)) ) |
#27 |
AH
Moving a way from Scheme, but on the same subject, just tried this UDF for moving a valve wall, got this error again!!
" line 2: parse error. " Now what could be wrong with this, just ran through an interpreter. #include “udf.h” DEFINE_CG_MOTION(oscillate_valve,dt,vel,omega,time ,dtime ) { Thread*t; face_t f; t=DT_THREAD(dt); begin_f_loop(f,t) { if(time>=0.03744 && time<=0.0383) vel[1]=5.0; if (time<0.03744 && time>0.0383) vel[1]=-5.0; else vel[1]=0.0; } end_f_loop(f,t) } |
#28 |
AH
Now tried another way to move valve wall in 3D, got this error message:
" line 9: structure reference not implemented " What the code should do, is move the valve with positive and negative velocities in the given time conditions, and therefore controlling distance movement. #include "udf.h" #include "threads.h" DEFINE_ADJUST(Valve_adjust,domain) { /*NOTE; wall ID is 36*/ Thread *thread = Lookup_Thread(domain, 36); real current_time = RP_Get_Real("flow-time"); if (current_time>= 0.0374 && current_time<=0.0383) THREAD_VAR(thread).wall.translate_mag = 5; Else if (current_time> 0.0383 && current_time<=0.03882) THREAD_VAR(thread).wall.translate_mag = -5; Else THREAD_VAR(thread).wall.translate_mag = 0; } |
#29 | |
Alexander
#30 |
AH
I did try to compile, these are the errors.
24 Aug moving wall define cg.c(2,1): warning: type specifier missing, defaults to 'int' [-Wimplicit-int] DEFINE_CG_MOTION(oscillate_valve,dt,vel,omega,time ,dtime ) ^ 24 Aug moving wall define cg.c(4,1): error: use of undeclared identifier 'Thread' Thread*t; ^ 24 Aug moving wall define cg.c(4,8): error: use of undeclared identifier 't' Thread*t; ^ 24 Aug moving wall define cg.c(5,1): error: use of undeclared identifier 'face_t' face_t f; ^ 24 Aug moving wall define cg.c(6,1): error: use of undeclared identifier 't' t=DT_THREAD(dt); ^ 24 Aug moving wall define cg.c(7,14): error: use of undeclared identifier 'f' begin_f_loop(f,t) ^ 24 Aug moving wall define cg.c(7,16): error: use of undeclared identifier 't' begin_f_loop(f,t) ^ 1 warning and 7 errors generated. scons: *** [24 Aug moving wall define cg.obj] Error 1 scons: building terminated because of errors. Done. latest version timings changed. #include “udf.h” DEFINE_CG_MOTION(oscillate_valve,dt,vel,omega,time ,dtime ) { Thread*t; face_t f; t=DT_THREAD(dt); begin_f_loop(f,t) { if(time>=0.000104 && time<=0.000624) vel[1]=5.0; if (time>0.000624 && time<=0.001144) vel[1]=-5.0; else vel[1]=0.0; } end_f_loop(f,t) } |
#31 |
AH
I don't understand why Fluent hasn't made this easy. This should be menu driven or allow an expression to move a boundary wall in 2/3D, just a suggestion for Fluent.
#32 |
AH
After trying out various UDFs which because of code errors non worked, I am now looking for a scheme code example. Just to explore if scheme can move 2/3D walls embedded in a mesh.
#33 |
AH
This for you Alex if you can help out, you are the scheme expert.
Made some changes and got this error message; " Error: eval: unbound variable Error Object: flag " this the scheme code. (define (outlet_BC_type_Change) (define time-sequence #(0.0 0.0374)) (define type-sequence #(1 2)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((1 0 (+ 1 1))) ((= 1 (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) (if (= flag 1) (ti-menu-load-string (format #f “define bou zone type 7 wall”))) (if (= flag 2) (ti-menu-load-string (format #f “define bou zone type 7 pressure-outlet”)) )) (newline) (if (= flag 1) (display “Exhaust BC now wall”)) (if (= flag 2) (Display “Exhaust BC now pressure outlet”)) ) |
#34 |
AH
Now I have tried something a bit different, controlling to BC with an if condition, but got this error .
" Error: eval: unbound variable Error Object: also " What I did in lines 22 and 23 I have started two 'ti' for wall 6 and 11. At line 27 started an if condition statement which; *sets wall 6 as a pressure-inlet "true condition" if flow-time is less than 0.0052 seconds, and *a "false condition" which sets wall 11 as pressure-inlet, this means this change in BC can occur after 0.0052 seconds. Lines 31 and 33 define BCs for wall 6 and 11. What could be the error?? Please and thanks. (define (inlet_BC_type_Change) (define time-sequence #(0 0.0052)) (define type-sequence #(2 1)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) ( if (= flag 1) (ti-menu-load-string (format #f “define bou zone type 6 wall”)) (ti-menu-load-string (format #f “define bou zone type 11 wall”)) ) (if (= flag 2) ( if (< (rpgetvar ‘flow-time) 0.0052) (ti-menu-load-string (format #f “define bou zone type 6 pressure-inlet”) (ti-menu-load-string (format #f “define bou zone type 11 pressure-inlet”) ) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 6 yes no 1.1e5 no 1 no 400 no yes”)) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 11 yes no 1.1e5 no 1 no 400 no yes”)) )) (newline) (if (= flag 1) (display “Exhaust BC now wall”)) (if (= flag 2) (Display “Exhaust BC now pressure inlet”)) ) |
#35 |
Alexander
each if statement can have only one tru and one false condition
try this code Code:
(define (inlet_BC_type_Change) (define time-sequence #(0 0.0052)) (define type-sequence #(2 1)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) (if (= flag 1) (begin (ti-menu-load-string (format #f “define bou zone type 6 wall”)) (ti-menu-load-string (format #f “define bou zone type 11 wall”)) ) ) (if (= flag 2) (if (< (rpgetvar ‘flow-time) 0.0052) (begin (ti-menu-load-string (format #f “define bou zone type 6 pressure-inlet”)) (ti-menu-load-string (format #f “define bou zone type 11 pressure-inlet”)) ) (begin (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 6 yes no 1.1e5 no 1 no 400 no yes”)) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 11 yes no 1.1e5 no 1 no 400 no yes”)) ))() ) (newline) (if (= flag 1) (display “Exhaust BC now wall”)) (if (= flag 2) (Display “Exhaust BC now pressure inlet”)) )
#36 |
AH
Thanks but maybe I did not explain properly, BC 6 and 11 need to change BC type at different times within the 0.0052 seconds time. Example BC 6 changes BC type at 0.0050 seconds, and BC 11 changes type at 0.0052 seconds.
So starting from line 26, how about this? Flag 2 is split up into two if conditions, the rest should follow. THANKS. (if (= flag 2) (if (< (rpgetvar ‘flow-time) 0.005) ( begin (ti-menu-load-string (format #f “define bou zone type 6 pressure-inlet”)) ) (if (= flag 2) (if (< (rpgetvar ‘flow-time) 0.0052) ( begin (ti-menu-load-string (format #f “define bou zone type 11 pressure-inlet”)) ) (begin (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 6 yes no 1.1e5 no 1 no 400 no yes”)) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 11 yes no 1.1e5 no 1 no 400 no yes”)) ))() ) |
#37 |
AH
How about this Alex, from line 26 onwards, I have split up flag 2 with two time based if condition statements, less than 0.0050 & less than 0.0052 seconds. After 0.0052 seconds, flag 1 will prevail and switch both BC to walls. I am a bit concerned about the use of brackets, maybe I got mixed up after line 26 and towards the end.
----- (define (Two_BC_type_Changes) (define time-sequence #(0 0.0052)) (define type-sequence #(2 1)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) (if (= flag 1) (begin (ti-menu-load-string (format #f “define bou zone type 6 wall”)) (ti-menu-load-string (format #f “define bou zone type 11 wall”)) ) ) (if (= flag 2) (if (< (rpgetvar ‘flow-time) 0.0050) ( begin (ti-menu-load-string (format #f “define bou zone type 6 pressure-inlet”)) ) (if (< (rpgetvar ‘flow-time) 0.0050) ( begin (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 6 yes no 1.1e5 no 1 no 400 no yes”) ) (if (> (rpgetvar ‘flow-time) 0.0050) ( begin (ti-menu-load-string (format #f “define bou zone type 11 pressure-inlet”)) ) (if (> (rpgetvar ‘flow-time) 0.0050) ( begin (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 11 yes no 1.1e5 no 1 no 400 no yes”)) ) ) (newline) (if (= flag 1) (display “Exhaust BC now wall”)) (if (= flag 2) (Display “Exhaust BC now pressure inlet”)) ) Last edited by visitor; August 29, 2022 at 15:52. |
#38 |
AH
Dear Alex another question for you, hope you can help out. Thanks.
What about if I want the 'if' condition to have this time limits; > 0.005 && <= 0.00572. Is the line below acceptable in scheme? (if (> (rpgetvar 'flow-time) 0.005 && <=(rpgetvar 'flow-time) 0.00572) Maybe I should get rid of the 'if' condition, instead use this? (and (> (rpgetvar 'flow-time) 0.005) (<=(rpgetvar 'flow-time) 0.00572)) |
#39 |
AH
Latest run with errors, it sounds I got brackets missed somewhere.
What this code does now; keeps walls closed when flag 1, but with flag 2 opens walls under specific time spans using the "cond" & "and" conditions rather than "if" conditions. " Error: eof inside list Error Object: () " (define (Two_BC_type_Changes) (define time-sequence #(0 0.00572 0.03276)) (define type-sequence #(2 1 2)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.000104 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.000104 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) (if (= flag 1) (begin (ti-menu-load-string (format #f “define bou zone type 24 wall”)) (ti-menu-load-string (format #f “define bou zone type 23 wall”)) (ti-menu-load-string (format #f “define bou zone type 11 wall”)) (ti-menu-load-string (format #f “define bou zone type 12 wall”)) ) ) (if (= flag 2) (cond [(and (> (rpgetvar ‘flow-time) 0.0) (< (rpgetvar ‘flow-time) 0.0050)) (begin (ti-menu-load-string (format #f “define bou zone type 24 pressure-inlet”)))] [(and (> (rpgetvar ‘flow-time) 0.0) (< (rpgetvar ‘flow-time) 0.0050)) (begin (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 24 yes no 1.1e5 no 1 no 300 no yes”)))] [(and (> (rpgetvar ‘flow-time) 0.0050) (< (rpgetvar ‘flow-time) 0.0057)) (begin (ti-menu-load-string (format #f “define bou zone type 23 pressure-inlet”)))] [(and (> (rpgetvar ‘flow-time) 0.0050) (< (rpgetvar ‘flow-time) 0.0057)) (begin (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 23 yes no 1.1e5 no 1 no 300 no yes”)))] [(and (> (rpgetvar ‘flow-time) 0.03276) (<= (rpgetvar ‘flow-time) 0.05616)) (begin (ti-menu-load-string (format #f “define bou zone type 11 pressure-outlet”)))] [((> (rpgetvar ‘flow-time) 0.03346) (begin (ti-menu-load-string (format #f “define bou zone type 12 pressure-outlet”)))] ) (newline) (if (= flag 1) (display “Exhaust BC now wall”)) (if (= flag 2) (Display “Exhaust BC now pressure inlet”)) |
#40 |
AH
Why this error in flag 1, "too many arguments"? How can this be rectified? I was more concerned about flag 2, because of the newly introduced 'cond' statement!
Should flag 1 be segrageated into four parts, eg.; ((= flag 1) (ti-menu-load-string (format #f “define bou zone type 24 wall”))) ((= flag 1) (ti-menu-load-string (format #f “define bou zone type 23 wall”))) ((= flag 1) (ti-menu-load-string (format #f “define bou zone type 11 wall”))) ((= flag 1) (ti-menu-load-string (format #f “define bou zone type 12 wall”))) Or maybe there is a better way? I am still concerned with brackets, I hope it's OK. THANKS in advance! ------- Error: if syntax: Too many arguments Error Object: ((= flag 1) (ti-menu-load-string (format #f �define bou zone type 24 wall�)) (ti-menu-load-string (format #f �define bou zone type 23 wall�)) (ti-menu-load-string (format #f �define bou zone type 11 wall�)) (ti-menu-load-string (format #f �define bou zone type 12 wall�))) ===== (define (changeboundary) (define time-sequence #(0 (390*0.000104) (670*0.000104)) (define type-sequence #(2 1 2)) (define flag 0) (define bctype 0) (define time (rpgetvar ‘flow-time)) (define dt (rpgetvar ‘physical-time-step)) (set! flag 0) (set! bctype 0) (do ((i 0 (+ i 1))) ((= i (vector-length time-sequence))) (if (>= time (- (vector-ref time-sequence i) (* 0.5 dt))) (if (<= time (+ (vector-ref time-sequence i) (* 0.5 dt))) (set! flag 1) (set! bctype (vector-ref type-sequence i)) ))) (if (= 1 bctype) (if (= flag 1) (set! flag 2))) (if (= flag 1) (ti-menu-load-string (format #f “define bou zone type 24 wall”)) (ti-menu-load-string (format #f “define bou zone type 23 wall”)) (ti-menu-load-string (format #f “define bou zone type 11 wall”)) (ti-menu-load-string (format #f “define bou zone type 12 wall”))) (if (= flag 2) Cond (> (rpgetvar ‘flow-time) (200*0.000104)) (ti-menu-load-string (format #f “define bou zone type 11 pressure-outlet”)) (> (rpgetvar ‘flow-time) (200*0.000104)) (ti-menu-load-string (format #f “define bou zone type 12 pressure-outlet”)) (> (rpgetvar ‘flow-time) (165*0.000104)) (ti-menu-load-string (format #f “define bou zone type 24 pressure-inlet”)) (> (rpgetvar ‘flow-time) (165*0.000104)) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 24 yes no 1.1e5 no 1 no 400 no yes”)) (> (rpgetvar ‘flow-time) (165*0.000104)) (ti-menu-load-string (format #f “define bou zone type 23 pressure-inlet”)) (> (rpgetvar ‘flow-time) (165*0.000104)) (ti-menu-load-string (format #f “define boundary-conditions pressure-inlet 23 yes no 1.1e5 no 1 no 400 no yes”)) (> (rpgetvar ‘flow-time) (200*0.000104)) (ti-menu-load-string (format #f “define bou zone type 11 wall”)) (> (rpgetvar ‘flow-time) (200*0.000104)) (ti-menu-load-string (format #f “define bou zone type 12 wall”)) (> (rpgetvar ‘flow-time) (390*0.000104)) (ti-menu-load-string (format #f “define bou zone type 23 wall”)) (> (rpgetvar ‘flow-time) (390*0.000107)) (ti-menu-load-string (format #f “define bou zone type 24 wall”)) (> (rpgetvar ‘flow-time) (670*0.000104)) (ti-menu-load-string (format #f “define bou zone type 11 pressure-outlet”))) (else (> (rpgetvar ‘flow-time) (673*0.000104)) (ti-menu-load-string (format #f “define bou zone type 12 pressure-outlet”))) ) (newline) (if (= flag 1) (display “Boundaries set as walls”)) (if (= flag 2) (Display “Boundaries open/close depending on timings”)) ) |
UDF switching with a conditional statement | visitor | FLUENT | 15 | July 5, 2019 12:28 |
Ansys Fluent 17.0 Expression | u_k | FLUENT | 8 | May 13, 2019 06:15 |
Surface tension force expression at the wall in fluent | IndrajitW | FLUENT | 0 | April 15, 2013 08:37 |
Conditional statement over the entire mesh | xisto | OpenFOAM Programming & Development | 6 | November 24, 2010 12:13 |
CFX Expression Statement | Ivan | CFX | 3 | June 5, 2006 11:42 |
