Please help - Assign volatile mass fraction to particle |
July 14, 2022, 10:29 |
Benjamin Ortner
Rep Power: 5 |
Hello everyone!
I am using the DEFINE_DPM_INJECTION_INIT from the UDF guide because I need to assign initial char and volatile massfractions to my particles - additionaly to the standard properties - but I just cant get it to work. The UDF from the manual is fine, I can even assign the volatile fraction from a file to the USER_REAL which they describe in the documentation, but fluent does not let me write to the DPM_VOLATILE_FRACTION(p). So I know reading from the file is not the problem. What am I doing wrong here? Fluent ignores my code and after initialization the particles have the same volatile and char mass fraction according to the material definition. This works: /* From the rest of the line, determine the volatile mass fraction, * add assign to the new particle’s user real */ sscanf(strchr(rest, ':')+1, "%lg", &(PP_USER_REAL(p, 0))); This does not: /* From the rest of the line, determine the volatile mass fraction, * add assign to DPM_VOLATILE_FRACTION */ sscanf(strchr(rest, ':')+1, "%lg", &(DPM_VOLATILE_FRACTION(p))); Thank you in advance! |
July 14, 2022, 22:31 |
Alexander
Rep Power: 34 |
from my point of view, problem could be in initialization macro you are using,
VOLATILE_FRACTION could be not determined yet, howeve, you are trying to access the data
best regards ****************************** press LIKE if this message was helpful |
dpm, fluent, initialization, udf, volatile |
Filtering particle incident mass flux by particle velocity magnitude | Patrick_M | STAR-CCM+ | 0 | March 11, 2020 22:57 |
particle velocity field from twoPhaseEulerFoam when particle volume fraction is low | openfoammaofnepo | OpenFOAM | 0 | June 28, 2017 19:51 |
Conversion of mass fraction to mole fraction in FLUENT | prince_pahariaa | FLUENT | 0 | August 26, 2014 09:08 |
Water subcooled boiling | Attesz | CFX | 7 | January 5, 2013 04:32 |
DPM UDF particle position using the macro P_POS(p)[i] | dm2747 | FLUENT | 0 | April 17, 2009 02:29 |
