Problem using flow variables inside a macro
Old   June 27, 2022, 11:53
Default Problem using flow variables inside a macro
Siddharth
sidkamat is on a distinguished road
Hello. I am trying to introduce a force in the DPM_BODY_FORCE macro in the DPM model. The force is dependent on the flow velocity so I want to incorporate the flow velocity into the equation. My code is:
DEFINE_DPM_BODY_FORCE(DEP,tp,i)
double beta=L/D;
double xi=beta/sqrt((beta*beta-1));
double c1=0.5*log((xi+1)/(xi-1));
double f=xi*((1-xi*xi)*c1*xi+xi);
double Fd=0;
if (TP_POS(tp)[0] >= 0.05)
if(i == 1)
Fd = -1* (pi * km * epsilon * D * D * L / 6) / (alpha / (alpha - 1) - f) * pow(V / log(R2 / R1), 2) * pow(1 / TP_POS(tp)[1], 3)+pi*mu*D*4* fabs(TP_VEL(tp)[1])*(pow(beta,2)-1)/((2*pow(beta,2)-1)*(log(beta+sqrt(pow(beta,2)-1))/sqrt(pow(beta,2)-1)-beta));
else if (i == 0)
Fd = -1*pi * mu * D * fabs(C_U(c,t)-TP_VEL(tp)[0]) * 8 * (pow(beta, 2) - 1) / ((2 * pow(beta, 2) - 3) * (log(beta + sqrt(pow(beta, 2) - 1)) / sqrt(pow(beta, 2) - 1) + beta));
return(Fd/TP_MASS(tp));
I am getting the following error during compilation:
error: use of undeclared identifier 'c'
error: use of undeclared identifier 't'
Is this because I am using the flow variables in a different macro that does not have the variables t & c in its declaration. If yes, how do I fix this.
Some help would be appreciated.
sidkamat is offline   Reply With Quote
Old   June 30, 2022, 06:08
Mohammad Shafiee
Mohammad74 is on a distinguished road
You have not defined c and t as variables in your macro, and thats what the error means. If you defined them somewhere else (like in another macro, in this source fille), and want to use their value here, you should define them as global variables in your source file. Which makes them visible to all the macros inside the said source file.
Mohammad74 is offline   Reply With Quote
Old   July 4, 2022, 08:47
Default Cell loop?
thedal's Avatar
Thamilmani M
thedal is on a distinguished road
double beta=L/D;
double Fd=0;
if(i == 1)
else if (i == 0)
Two things:
1. Yes, you either declare c and t as global variable and calculate the flow variable but even if you declare it outside. I am not sure where the value of cell ID and thread pointer values you will get.
2. So, I suppose you use a cell loop to loop through all the cells and calculate the value I guess for which you have to define c and t inside the macro also.
Always
Thedal
thedal is offline   Reply With Quote
dpm bodyforce, fluent - udf, udf compilation
Problem with FsiFOAM simulation of beams (2-4 beams) in a steady simple shear flow Aliiiii OpenFOAM Running, Solving & CFD 1 February 27, 2019 13:26
transient, impregnating flow problem fgommer FLUENT 0 February 29, 2012 17:10
Simulation of air flow inside valve - FSI? Help! farianka Main CFD Forum 0 April 17, 2011 17:30
Modelling the Heat flow inside the curing oven Marios Vlad CFX 1 February 6, 2008 08:11
Poiseuille flow problem Rosie FLUENT 1 December 6, 2002 17:52
