Parcel Model Not Compatible with UDF Initial Injection |
June 23, 2022, 15:17 |
Ohio
Rep Power: 4 |
Hello everyone,
I am relatively new to CFD modeling and have been working in Fluent on the 2021 R2 version of the ANSYS workbench. I am using a discrete phase model and am having an issue where I have written a UDF and whenever I try to create an injection, Fluent returns the message: "The Parcel model is not compatible with the udf-injection-init. The model will be disabled and the standard parcel release method will be applied." I would like to use the constant-mass parcel release method, but as it is now, Fluent will only let me run the standard parcel release method. I am not sure why my udf is not working, any help with this matter would be greatly appreciated! I have attached the relevant portion of my udf below and specified the settings for the injection as well. UDF: DEFINE_DPM_INJECTION_INIT(init_Intelligent,I) /*Init for particles by Intelligent option */ { Particle *p; loop(p,I->p) { PP_USER_REAL(p, 0) = 0.; PP_USER_REAL(p, 1) = PP_MASS(p) * (p->number_in_parcel); PP_USER_REAL(p, 2) = 10.0; /* Intelligent option */ PP_POS(p)[2] = 0.1; /* for check */ } } Injection Information: X-pos(m):-2.538 Y-pos(m):0.84 Z-pos(m):3.6576 X-vel(m/s):11.0475 Y-Vel(m/s):-3.6024 Z-vel(m/s):0.89408 Diameter(m):0.0001092 Temperature(K): 283.15 Flow Rate(kg/s):0.0021373 Start Time(s):0 Stop Time(s):4.0909 Drag Law: dynamic drag Breakup: breakup enabled, TAB model used with y0=0, breakup parcels=2 Injection type: single Particle type: droplet Material: water-liquid Evaporating species: h2o Stochastic tracking: Discrete random walk model and random eddy lifetime enabled, number of tries = 1, Time-scale constant = 0.15 Parcel release method: constant mass Parcel mass: 1*10^-6 UDF Initialization: init_intelligent::UDF_UM |
constant mass, dpm, fluent, parcel model, udf |
Suppress twoPhaseEulerFoam energy | AlmostSurelyRob | OpenFOAM Running, Solving & CFD | 33 | September 25, 2018 18:45 |
simpleFoam error - "Floating point exception" | mbcx4jc2 | OpenFOAM Running, Solving & CFD | 12 | August 4, 2015 03:20 |
Unstabil Simulation with chtMultiRegionFoam | mbay101 | OpenFOAM Running, Solving & CFD | 13 | December 28, 2013 14:12 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
