June 3, 2022, 11:31 |
how to print parameters on console
sheida
Rep Power: 5 |
Hello experts
I want to print some parameters I've defined their formula on the console, therefore I used bellow code: printf("i=%d omega[i-1] HH[i-1] random=%d frandom=%f phi=%f\n",i,omega[i-1], HH[i-1] random,frandom,random_PHI[i-1]); but when I initialize nothing printed on console, even when I run my code which gives me the correct results at the end, non of mentioned parameters are printed. some friends said if I am going to compile my code I should write *message* instead of *printf* but no change was observed. Do you now what should I do? |
June 7, 2022, 03:43 |
Alexander
Rep Power: 34 |
compile with *message* instead of *printf*
that should print what you want into console if not, probably there is a problem with logic in your code show your code here
best regards ****************************** press LIKE if this message was helpful |
printing, udf |
how to get Sutherland and JANAF coefficients of air? | immortality | OpenFOAM Running, Solving & CFD | 64 | October 18, 2022 10:17 |
Print to console simulated plots | ma_martinez | FLUENT | 5 | March 25, 2020 14:54 |
Pro/E to ANSYS Parameterization Guide | Trues | ANSYS | 4 | April 18, 2018 05:52 |
Hybrid discretisation - blend factor | gcoopermax | CFX | 5 | September 23, 2016 08:05 |
[blockMesh] Another cylinder question | bendel_boy | OpenFOAM Meshing & Mesh Conversion | 5 | January 6, 2015 05:09 |
