Define grid motion udf issue: Wing geometry breaks down with time |
June 1, 2022, 11:22 |
I'm developing of CFD pipeline for a flapping wing with ANSYS Fluent, including 4 degrees of freedom: rotations about the three axes plus a spanwise twist. I've used define cg motion udf to simulate wing motion as a rigid body (i.e. without incorporating the twisting deformation) and that works just fine, but I face a problem when using the define grid motion udf to apply the twisting wing deformation. It seems that the wing becomes distorted rapidly if I use a time step smaller than 1e-5 seconds. If I use a time step equal to 1e-5 I can see the wing slowly expanding, almost doubling in size a few cycles in (see attachements). Switching to an even smaller time step, 1e-6, seems to reduce the problem to non-noticable levels, at least for the first 10 cycles or so that I've tested it for. Does anyone have an idea why this is the case, and/or any suggestions on how to deal with the problem? I'm looking for a solution that eliminates the problem altogether rather than reduces it (as seemingly does, for example, decreasing the time step). I would greately appreciate your advice! Many thanks! |
grid motion, time step, udf, wing deformation, wing flapping |
Laminar Kinetic Energy Model (Walters 2008) | logoswort | Fluent UDF and Scheme Programming | 2 | May 19, 2017 19:41 |
pressure in incompressible solvers e.g. simpleFoam | chrizzl | OpenFOAM Running, Solving & CFD | 13 | March 28, 2017 05:49 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 13:58 |
dynamic Mesh is faster than MRF???? | sharonyue | OpenFOAM Running, Solving & CFD | 14 | August 26, 2013 07:47 |
Can I define grids motion as a time functions | Darcy | CFX | 4 | March 29, 2001 21:14 |
