Problem with UDS and UDM.
Old   April 14, 2022, 09:01
Default Problem with UDS and UDM.
KLD
KHALID
KLD is on a distinguished road
Hi everybody,
I'm doing a simulation of an electrodepostion process and I need to code a UDS and UDM (below) to calculate the thickness of the zinc layer on my cathode (Domain ID=2). The problem is that I'm getting a zero FOR THE UDS and the UDM just like it doesn't work.
Any help well be appreciated.
Thanks.
# include "udf.h"
# define domain_ID 2
DEFINE_EXECUTE_AT_END(adjust_gradient)
Domain *domain;
Thread *t;
cell_t c;
face_t f;/*real F=0.0044910826582479*/
real J;
real *E;
real EMag;
real sigma= 20;
domain=Get_Domain(2);
/* Fill UDS with the variable. */
thread_loop_c (t,domain)
begin_c_loop (c,t)
E=C_PHI_1_G(c,t);/*call potential gradient vector from adjacent cell of the face*/
EMag=NV_MAG(E);/*magnitude of potential gradient vector*/
J=sigma*EMag;/*current density*/
C_UDSI(c,t,0)=C_UDSI_M1(c,t,0)+((0.1475*J)-0.0963)*J*0.0044910826582479;/*cathode thickness*/
end_c_loop (c,t)
thread_loop_f (t,domain)
if (THREAD_STORAGE(t,SV_UDS_I(0))!=NULL)
begin_f_loop (f,t)
E=C_PHI_1_G(F_C0(f,t),THREAD_T0(t));/*call potential gradient vector from adjacent cell of the face*/
J=sigma*EMag;
F_UDSI(f,t,0)=C_UDSI_M1(F_C0(f,t),THREAD_T0(t),0)+ ((0.1475*J)-0.0963)*J*0.0044910826582479;
end_f_loop (f,t)
DEFINE_EXECUTE_AT_END(store_gradient)
Domain *domain;
cell_t c;
Thread *t;
/* Fill the UDM with magnitude of gradient. */
begin_c_loop (c,t)
C_UDMI(c,t,0) =C_UDSI_M1(c,t,0)+NV_MAG(C_UDSI_G(c,t,0));
end_c_loop (c,t)
KLD is offline   Reply With Quote
Old   April 14, 2022, 23:32
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
first, do you have multiphase flow?
as you are using "domain=Get_Domain(2);" for single phase domain is always 1.
As you are using value from previous timestep C_UDSI_M1(c,t,0) how did you organize it for the first time step? Previous timestep doesn't exist yet.
Probably, better to define *E as a vector explicitly:
real NV_VEC(E);
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
udf code, udm; udf; profile;, udmi.uds, uds equation
Different values for identical UDS and UDM FarzinD Fluent UDF and Scheme Programming 26 August 3, 2022 08:10
Adjusting UDM to UDS mvee Fluent UDF and Scheme Programming 16 June 26, 2018 05:30
Segmentation violation louiza FLUENT 16 June 27, 2017 16:41
UDS stored to UDM do not show the same values swati_mohanty FLUENT 0 December 3, 2010 04:46
usage of UDS & UDM Tong FLUENT 2 February 15, 2006 11:32
