April 7, 2022, 06:23 |
Calculating gradient of ln(C)
Jeroen de Graaff
Rep Power: 4 |
Hey everyone!
In a user-defined source term, I need access to the ln(mass_concentration) gradient. I tried to define a UDSI as the ln(density*massfrac). And then access the gradient of UDSI with C_UDSI_G(c,t,0). However, this seems to yield an error when iterating. I defined the UDSI as a define_adjust function and hooked it into fluent. Then I am trying to call the gradient of the UDSI in the defined_source function. Also good to note is that both functions compile without error and to make sure that I do not get the ln(x->0) = -inf, I add + 1e*-12 inside the ln function. My question is if someone can help me obtain this gradient, I am not quite sure if my approach is the correct one and if so where it goes wrong. All help will be deeply appreciated. |
April 7, 2022, 08:01 |
Jeroen de Graaff
Rep Power: 4 |
It seems that the define_adjust function is the problem. To make sure I have access to the gradient I do use the text command /solve/set/expert and answer yes to “Keep temporary solver memory from being freed?”. I am not quite sure what seems to be the problem. Just as a reference I include the code below.
DEFINE_ADJUST(adjust_gradient, domain) { Thread* t; cell_t c; face_t f; /* Fill UDS with the variable. */ thread_loop_c(t, domain) { begin_c_loop(c, t) { C_UDSI(c, t, 0) = log(C_YI(c, t, 0) * C_R(c, t) + 1e-12); } end_c_loop(c, t) } thread_loop_f(t, domain) { if (THREAD_STORAGE(t, SV_UDS_I(0)) != NULL) begin_f_loop(f, t) { F_UDSI(f, t, 0) = log(F_YI(f, t, 0) * F_R(f, t) + 1e-12); } end_f_loop(f, t) } } |
gradient calculation, uds gradient of scalar, udsi |
pisoFOAM (LES) - internal pipe flow - convergence | gu1 | OpenFOAM Running, Solving & CFD | 0 | January 11, 2018 16:39 |
question regarding LES of pipe flow - pimpleFoam | Dan1788 | OpenFOAM Running, Solving & CFD | 37 | December 26, 2017 14:42 |
Periodic flow using Cyclic - comparison with Fluent | nusivares | OpenFOAM Running, Solving & CFD | 30 | December 12, 2017 05:35 |
[General] Problem in calculating Gradient | masaaki | ParaView | 0 | March 16, 2015 06:38 |
How to update polyPatchbs localPoints | liu | OpenFOAM Running, Solving & CFD | 6 | December 30, 2005 17:27 |
