March 31, 2022, 09:40 |
Calculation of F_UDMI by C_UDMI - error
Chris
Rep Power: 5 |
Hey, simple question: I would like to calculate a field magUp and save it with UDM for face and cell.
When I use the following code, everything works perfectly expect the last part for the F_UDMI. The program crashes, when I try to use the "C1" commands. Can you explain this? What am I doing wrong? Side question: How can I write the part with UgofU... and Up... with the NV_D, NV_DS etc. commands? I run lots of errors trying to do this. Thanks in advance Chris Code:
#include "udf.h" #include "math.h" DEFINE_EXECUTE_ON_LOADING(Load_UDM_Up, libname) { Set_User_Memory_Name(0,"Up"); Message("UDM id 0 reserved for Up.\n"); } DEFINE_ADJUST(ADJUST_Up,d) { Thread *t; cell_t c; face_t f; real K = 5; // (unit: s) real Up_mag; thread_loop_c(t,d) { begin_c_loop(c,t) { real UgofU = C_U(c,t) * C_U_G(c,t)[0] + C_V(c,t) * C_U_G(c,t)[1] + C_W(c,t) * C_U_G(c,t)[2]; real VgofV = C_U(c,t) * C_V_G(c,t)[0] + C_V(c,t) * C_V_G(c,t)[1] + C_W(c,t) * C_V_G(c,t)[2]; real WgofW = C_U(c,t) * C_W_G(c,t)[0] + C_V(c,t) * C_W_G(c,t)[1] + C_W(c,t) * C_W_G(c,t)[2]; real Up = C_U(c,t) - UgofU * K; real Vp = C_V(c,t) - VgofV * K; real Wp = C_W(c,t) - WgofW * K; Up_mag = sqrt(pow(Up,2) + pow(Vp,2) + pow(Wp,2)); C_UDMI(c,t,1) = Up_mag; } end_c_loop(c,t) begin_f_loop(f,t) { if(BOUNDARY_FACE_THREAD_P(t)) // Face is part of boundary field { F_UDMI(f,t,1) = C_UDMI(F_C0(f,t),F_C0_THREAD(f,t),1); } else // Face is part of internal field { F_UDMI(f,t,1) = (C_UDMI(F_C0(f,t),F_C0_THREAD(f,t),1) + C_UDMI(F_C1(f,t),F_C1_THREAD(f,t),1)) / 2; } } end_f_loop(f,t) } } |
February 23, 2023, 13:22 |
Rep Power: 7 |
connectivity macro of C1 doesnt exist in boundary face thread of a wall |
define_adjust, f_udmi, udmi |
Compile calcMassFlowC | aurore | OpenFOAM Programming & Development | 13 | March 23, 2018 07:43 |
Undeclared Identifier Errof UDF | SteveGoat | Fluent UDF and Scheme Programming | 7 | October 15, 2014 07:11 |
Errors in UDF | shashank312 | Fluent UDF and Scheme Programming | 6 | May 30, 2013 20:30 |
CGNS lib and Fortran compiler | manaliac | Main CFD Forum | 2 | November 29, 2010 06:25 |
How to get the max value of the whole field | waynezw0618 | OpenFOAM Running, Solving & CFD | 4 | June 17, 2008 05:07 |
