UDF/SCHEME to Change Individual Cell Boundary Conditions Based on Pressure |
March 29, 2022, 14:33 |
Anonymous
Rep Power: 4 |
I'm working on a detonation simulation where I need a boundary condition change to occur in the high-pressure region behind the wave. The 2-D simulation takes place in a rectangular domain with periodic boundaries on the sides, a pressure outlet exhaust on top, and an inlet at the bottom. The detonation wave is to travel along the inlet, continuously rotating. The goal is to have a total pressure inlet supplying propellant at all parts of the inlet whose pressure at the cell face along the inlet is less than the injection pressure. Those cell faces with higher pressure (immediately after detonation passes) need to be switched to a wall boundary condition. I've read some SCHEME setups that are able to change the boundary of the entire inlet with provided zone ID, but I haven't been able to come across anything that can change individual cell faces that are part of the boundary. In the past, I've used a UDF to switch between total pressure inlets and supersonic pressure inlets, but the switch between two completely different types is turning out to be more difficult. Does anyone have any experience with this kind of change? Any help would be greatly appreciated. Thank you. |
March 30, 2022, 09:53 |
Rep Power: 5 |
I think fluent has can separate surfaces to faces. if you are willing to write a switch statement from Wall-Inlet, theoretically, you should be able to switch the faces of a surface individually by some kind of a generalized if statement
March 31, 2022, 23:13 |
Alexander
Rep Power: 34 |
there is no way to switch between boundary conditions in specific cell/face
it is applied to the whole thread I see two ways for you here: 1. make a huge amount of faces with unique names (ids) so you may change BC types there 2. Change viscosity to huge value in that region, so the flow can't proceed there
best regards ****************************** press LIKE if this message was helpful |
sliding mesh problem in CFX | Saima | CFX | 46 | September 11, 2021 07:38 |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Fail to converge when solving with a fabricated solution | zizhou | FLUENT | 0 | March 22, 2021 06:33 |
Wrong multiphase flow at rotating interface | Sanyo | CFX | 14 | February 7, 2017 17:19 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
