March 23, 2022, 07:14 |
Wrong cell value for DEFINE_PROFILE
Chris
Rep Power: 6 |
Hi, I´m new to fluent udfs. I tired to implement some input viscous resistance using porous media:
DEFINE_PROFILE(Darcy_JJ,t,i) { cell_t c; real celli[ND_ND]; // Vector with dimensions of present case real z; real z_in = 8.107e-6; // Length of inlet in z real z_pm = 8.107e-6; // Length of porous media in z int Nz = 10; // Number of pm cells in z real dz = z_pm / Nz; // Length of single filter cell in z real Darcy = 3.2268e+13; begin_c_loop(c,t) { C_CENTROID(celli,c,t); z = celli[2]; if(celli[0] == 0 && celli[1] == 0) // Just to check the calculation { Message("Results for Cell coords: %g %g %g \n",celli[0],celli[1],celli[2]); Message("Results for multiplier: %g \n",((z-z_pm-dz/2)/dz + 1)); Message("Darcy: %g \n", Darcy * ((z-z_pm-dz/2)/dz + 1)); } C_PROFILE(c,t,i) = Darcy * ((z-zPF-dzF/2)/dzF + 1); C_UDMI(c,t,0) = C_PROFILE(c,t,i); } end_c_loop(c,t) } Thanks for any help in advance Chris |
March 31, 2022, 23:27 |
Alexander
Rep Power: 34 |
Actually I think that's the problem of your contours.
make the picture inside the fluent, turn off "node values" option while making contour. for the first cell you have gradient from 0 to value -> so picture may look as you expected, but the last cell has value to 0 gradient, so you may see some negative gradient. That's what I expect, didn't see our pictures actually
best regards ****************************** press LIKE if this message was helpful |
cell center, define profile, udf code |
problem during mpi in server: expected Scalar, found on line 0 the word 'nan' | muth | OpenFOAM Running, Solving & CFD | 3 | August 27, 2018 05:18 |
Wrong velocities at first cell of velocity inlet boundaries | Bahram | OpenFOAM Bugs | 9 | September 24, 2015 11:52 |
How to locate which cell goes wrong? | CjjJoy | OpenFOAM Running, Solving & CFD | 2 | March 22, 2015 21:16 |
meshing of a compound volume in GMSH | shawn3531 | OpenFOAM | 4 | March 12, 2015 11:45 |
Journal file error | magicalmarshmallow | FLUENT | 3 | April 4, 2014 13:25 |
