Udf define property
Old   March 20, 2022, 07:47
Default Udf define property
PXY
pxy
PXY is on a distinguished road
Hello everyone, I am learning Fluent, but I have a problem:
Can UDF get the value of another cell? For example, I want to define the viscosity of the cell, but I need to use the value of the cell adjacent to the wall. The line between these two points is perpendicular to the wall. I tried using Looping macros in DEFINE_PROPERTY Macros, or looping each cell in DEFINE_ADJUST Macro and then nested loops inside to get the value of the wall adjacent cell, but running would show: Received signal SIGSEGV. Is it because UDFs can't nest with loops?
Thank you very much!
here is my code
PXY is offline   Reply With Quote
Old   March 20, 2022, 08:15
PXY
pxy
[CODE]
#include"udf.h"
#include"mem.h"
#define F 0.4
#define B 500
#define g 9.81
#define h 0.3
#define l 0.0051
DEFINE_ADJUST(adjust, d)
#if !RP_HOST
Thread* t;
cell_t c;
face_t f;
real x[ND_ND], xc[ND_ND];
real a;
int ID1 = 11, ID2 = 35;
Thread* t1 = Lookup_Thread(d, ID1);
Thread* t2 = Lookup_Thread(d, ID2);
thread_loop_c(t, d)
begin_c_loop(c, t)
if (C_VOF(c, t) >= 0.70)
C_CENTROID(x, c, t);
if ((x[1] - x[0]) / 2 > -h)
a = (x[1] - x[0]) / 2;
begin_f_loop(f, t1)
Thread* t0 = THREAD_T0(t1);
cell_t c0 = F_C0(f, t1);
C_CENTROID(xc, c0, t0);
if (sqrt(pow((xc[1] - a), 2) + pow((xc[0] + a), 2)) < l)
C_UDMI(c, t, 1) = C_UDMI(c0, t0, 0);
end_f_loop(f, t1)
begin_f_loop(f, t2)
Thread* t0 = THREAD_T0(t2);
cell_t c0 = F_C0(f, t2);
if (sqrt(pow((xc[1] + h), 2) + pow((xc[0] - x[0]), 2)) < l)
end_f_loop(f, t2)
else
begin_f_loop(f, t2)
end_f_loop(f, t2)
end_c_loop(c, t)
#endif /* only compute nodes are involved */
[CODE]
How to define movement/deformation relative to a rigid body motion in Fluent by udf? eagle_001 Fluent UDF and Scheme Programming 6 May 17, 2022 04:41
using define mass transfer udf for cavitation Komon Fluent UDF and Scheme Programming 14 June 21, 2016 03:50
udf eror + Define property + density rezvan Fluent UDF and Scheme Programming 10 July 10, 2015 05:30
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation 129 June 19, 2010 10:23
UDF FOR UNSTEADY TIME STEP mayur FLUENT 3 August 9, 2006 11:19
