UDF and window console termination error/problem |
March 19, 2022, 13:05 |
bilal
Rep Power: 5 |
Dear Concern,
In Ansys Fluent, when I compile and load the UDF file, and also in the Cell zone conditions>Fluid I added/enabled the source term and uploaded the UDF file and even initialize but when I click on calculate, after 5 second the console window get terminated/crashed/disappeared. Before getting crashed I see this below error 999999: mpt_accept: error: accept failed: no such file or directory 999999: mpt_accept: error: accept failed: no such file or directory 999999: mpt_accept: error: accept failed: no such file or directory 999999: mpt_accept: error: accept failed: no such file or directory ----error analysis----- (0-1) on DESKTOP-145MM28 C: \ PROGRA ~1 \ANSYSI~1 \ ANSYSS~1\v212\fluent\fluent21.2.0\win64\2D_node\f1 m.exepi2021 ended prematurely and may have crashed exit code 2 ----error analysis----- I tried the other UDF sample model from fluent manual and it work well and get calculated. Kindly explain the possible mistake or the modification that I need to do in my attached UDF. #include "udf.h" #include "pdf_props.h" #include "pdf_table.h" #include "mem.h" #include "materials.h" /*********Constant Declarations*************************************/ #define c_alph 54.0 /* Units: 1/s */ #define N_avog 6.022045e+26 /* 1/kmol */ #define c_bet 1.0 /* no units */ #define rho_soot 1800.0 /* kg/m3 */ #define T_alph 21000.0 /* activation temperature of soot inception in K */ #define N_norm 1.0e+15 /* Moss-Brookes model: normalizing parameter */ #define l 1.0 /* l indicates the particle nucleation sensitivity to Pressure: defined as 1.0 for now */ #define PI 3.14159265358979324 /* Pi as a constant...alternatively pi=4.0*atan(1.0) */ #define SpNo 19 /* The number of species in the mechanism file: should be adjusted according to the mechanism */ #define Species 7 /* This is the index for the species of interest (CO2 in this case) */ /*********End Constant Declarations*********************************/ DEFINE_SOURCE(n_sourceterm, c, ct, dS, eqn) { /*********Variable Declarations*************************************/ double dNdT, dp, X_CO2, T, P, rho_cell, M, N, Ysoot, bNuc, R; double x[SpNo], y[SpNo]; /* x is the array for species mole fractions and y is the array for mass fractions */ int id_co2; /*********End Variable Declarations*********************************/ /*********Variable Assignments**************************************/ Material *mat = THREAD_MATERIAL(ct); id_co2 = mixture_specie_index(mat, "co2"); Pdf_XY(c, ct, x, y); /* Calling the species mole and mass fractions for this cell */ X_CO2 = x[id_co2]; /* arbitrarily defined for now */ T = C_T(c, ct); /* Temperature at the cell */ if (c == 400) Message("Temp is %g\n, species %", T); P = C_P(c, ct); /* Cell Presdsure */ if (c == 400) Message("Press is %g\n, ", P); rho_cell = C_R(c, ct); /* Cell average Density */ R = UNIVERSAL_GAS_CONSTANT; /* Universal gas constant is called with the built-in Fluent Macro */ Ysoot = C_UDSI(c, ct, 0); /* Calling soot mass fraction from m_sourceterm scalar */ if (c == 400) Message("Ysoot is %g\n, ", Ysoot); bNuc = C_UDSI(c, ct, 1); /* Calling soot number density from n_sourceterm scalar */ if (c == 400) Message("bNuc is %g\n, ", bNuc); /**********End Variable Assignments*********************************/ /**********Start Calculations************************************** */ M = rho_cell * Ysoot; N = bNuc * rho_cell * N_norm; dp = pow(((6.0 * M)/(PI * N * rho_soot)), (1.0/3.0)); dNdT = c_alph * N_avog * pow(((X_CO2 * P)/(R * T)), l) * exp(-1.0 * T_alph / T) - c_bet * pow(((24.0 * R * T) / ( rho_soot * N_avog)), 0.5) * sqrt(dp) * pow(N, 2); if (c == 400) Message("dNdT is %g\n, ", dNdT); /**********End of Calculations**************************************/ return (dNdT / N_norm); } |
March 31, 2022, 23:06 |
Alexander
Rep Power: 34 |
Did you define and allocate memory for scalar?
C_UDSI(c, ct, 0)
best regards ****************************** press LIKE if this message was helpful |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 03:30 |
Can I change the variable in UDF via Fluent console or window without compiling? | swtbkim | FLUENT | 0 | July 12, 2017 23:15 |
compiling udf at window Nt(64BIT) | noa | FLUENT | 3 | July 30, 2014 00:01 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 08:24 |
udf and graphic window | mohsen zendehbad | FLUENT | 0 | December 19, 2009 00:46 |
