Termination problem after loading the UDF file
Old   March 4, 2022, 02:38
Default Termination problem after loading the UDF file
bilal
hbilal1076 is on a distinguished road
Dear Concern,
In Ansys Fluent, when I compile and load the UDF file, and also in the Cell zone conditions>Fluid I added/enabled the source term and uploaded the UDF file and even initialize but when I click on calculate, after 5 second it become terminated and get closed and back to the main page (main page I means where all tab of geometry, mesh, setup, solution are listed).
I even tried the other UDF sample model from fluent manual and it also get terminated.
Kindly explain the possible mistake that I am doing.
Thank you very much for your time and assistance.
Sincerely,
Bilal
hbilal1076 is offline   Reply With Quote
Old   March 7, 2022, 00:24
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
show UDF code
show console output after you've loaded UDF.
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Old   March 7, 2022, 01:59
Default after compiling UDF and initializing, while calculating the fluent get crashed
bilal
Dear Prof. AlexanderZ,
Thank you very much for your reply.
Here is my UDF file.
#include "udf.h"
DEFINE_SOURCE(energy,c,t,ds,eqn)
/*FILE *fp;*/
real source,tep,sigma,Pamb,tamb;
real MW[14];
real XH2O,Xco,XCO2,pH2O,pco,pCO2;
real MWmix,sum=0;
real kapa,absH2O,absco,absCO2;
real a0,a1,a2,a3,a4,a5;
real b0,b1,b2,b3,b4,b5;
real c0,c1,C2,c3,c4;
real d0,d1,d2,d3,d4;
int i;
/*fp=fopen("properties.txt","a+");*/
tep=C_T(c,t);
MW[0]=2;
MW[1]=1;
MW[2]=40;
MW[3]=44;
MW[4]=4;
MW[5]=16;
MW[6]=17;
MW[7]=29;
MW[8]=33;
MW[9]=18;
MW[10]=28;
MW[11]=32;
MW[12]=34;
MW[13]=28;
sigma=0.000000056697;
Pamb=1.0;
tamb=298.0;
a0=18.741;
a1=-121.310;
a2=273.500;
a3=-194.05;
a4=56.31;
a5=-5.8169;
b0=-0.23093;
b1=1.12393;
b2=9.4153;
b3=-2.99880;
b4=0.51382;
b5=-.000018684;
c0=6.6334;
c1=-0.0035686;
C2=0.000000016682;
c3=0.00000000025611;
c4=-0.000000000000026558;
if(tep<=750)
d0=4.7869;
d1=-0.06953;
d2=0.000295775;
d3=-0.000000425732;
d4=0.000000000202894;
else
if(tep>750)
d0=10.09;
d1=-0.01183;
d2=0.0000047753;
d3=-0.000000000587209;
d4=-0.000000000000025334;
for(i=0;i<14;i++)
sum=sum+C_YI(c,t,i)/MW[i];
MWmix=1/sum;
XH2O=C_YI(c,t,9)*MWmix/18;
Xco=C_YI(c,t,10)*MWmix/28;
XCO2=C_YI(c,t,3)*MWmix/44;
pH2O=XH2O*Pamb;
pco=Xco*Pamb;
pCO2=XCO2*Pamb;
absCO2=a0+(a1*(1000/tep))+(a2*pow(1000/tep,2))+(a3*pow(1000/tep,3))+(a4*pow(1000/tep,4))+(a5*pow(1000/tep,5));
absco=d0+(d1*tep)+(d2*pow(tep,2))+(d3*pow(tep,3))+ (d4*pow(tep,4));
absH2O=b0+(b1*(1000/tep))+(b2*pow(1000/tep,2))+(b3*pow(1000/tep,3))+(b4*pow(1000/tep,4))+(b5*pow(1000/tep,5));
kapa=(absco*pco)+(absCO2*pCO2)+(absH2O*pH2O);
source=-(4*sigma*kapa*(pow(tep,4)-pow(tamb,4)));
ds[eqn]=0;
/*fprintf(fp,"abc");
fclose(fp);*/
return source;
Old   March 7, 2022, 02:19
bilal
When I click on calculate it start processing and after 2 second this error appeared in console and the fluent get crashed and disappeared and closed to the main window (main window I means where mesh, setup, result etc. are listed.
Old   March 7, 2022, 02:39
Alexander
remove this line
if(tep>750)
problem could be with mass fraction :
and
check carefully IDs of fractions 9, 10 and 3
if I were you I would print in console variable to check if they are defined properly
for(i=0;i<14;i++)
Message0("current sum -> %f, current mass -> %f, of fraction ->%d",sum,C_YI(c,t,i),i);
best regards
Old   March 8, 2022, 01:20
bilal
I removed
if(tep>750)
but still the same error, also you mentioned the problem in mass fraction but I don't know what will be the problem to edit?
Thank you
Bilal
Old   March 8, 2022, 01:22
Alexander
edit this part of code as following:
for(i=0;i<14;i++)
show the console output
best regards
Old   March 8, 2022, 01:59
bilal
I edited and used the below, but again the same Error.
For your convenience, I attached the error screen shot.
#include "udf.h"
/*FILE *fp;*/
real MW[14];
real MWmix,sum=0;
int i;
tep=C_T(c,t);
MW[0]=2;
MW[1]=1;
MW[2]=40;
MW[3]=44;
MW[4]=4;
MW[5]=16;
MW[6]=17;
MW[7]=29;
MW[8]=33;
MW[9]=18;
MW[10]=28;
MW[11]=32;
MW[12]=34;
MW[13]=28;
Pamb=1.0;
tamb=298.0;
a0=18.741;
a1=-121.310;
a2=273.500;
a3=-194.05;
a4=56.31;
a5=-5.8169;
b0=-0.23093;
b1=1.12393;
b2=9.4153;
b3=-2.99880;
b4=0.51382;
b5=-.000018684;
c0=6.6334;
c1=-0.0035686;
C2=0.000000016682;
if(tep<=750)
d0=4.7869;
d1=-0.06953;
d2=0.000295775;
d3=-0.000000425732;
else
d0=10.09;
d1=-0.01183;
d2=0.0000047753;
for(i=0;i<14;i++)
MWmix=1/sum;
pH2O=XH2O*Pamb;
pco=Xco*Pamb;
pCO2=XCO2*Pamb;
ds[eqn]=0;
fclose(fp);*/
return source;
Old   March 8, 2022, 05:55
Post
bilal
In Ansys fluent, as I am burning acetylene in oxygen rich region that give a product of H2O and CO2.
Therefore, I think my species order is C2H2,O2,H2O,CO2 shown in screenshot but the UDF I am using contain the species order of CO,CO2,H2O, already pasted/shared above, so is this the mistake I am doing?
If this is the mistake then I have to add variable for C2H2 and O2 also?
Actually I am trying to find the temperature and mole fraction of CO2 and H2O for each Grid, therefore my question is
(1) should I just need to remove the species CO from the above shared UDF code and no need to add C2H2 and O2?
(2) or remove the specie CO and add C2H2 and O2 to the above code?
Your comment/assistance will be highly appreciated
TIA
[OpenFOAM.com] swak4foam compiling issues on a cluster saj216 OpenFOAM Installation 5 January 17, 2023 17:05
[swak4Foam] Installation Problem with OF 6 version Aurel OpenFOAM Community Contributions 14 November 18, 2020 17:18
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
friction forces icoFoam ofslcm OpenFOAM 3 April 7, 2012 11:57
