For Loops as part of an Adjust
Old   January 31, 2022, 17:01
Default For Loops as part of an Adjust
Pierce
PierceH is on a distinguished road
I'm trying to add an actuator disk into my simulation which involves creating an X-momentum source code. In order to create a Gaussian distribution over every cell (p) where the actuator disk lies I've created a for loop however upon implementing the adjust function to fluent the solution will not iterate once after 5 minutes (Fluent is not crashing).
Any suggestions?
See the code here
DEFINE_ADJUST(adjust1,d)
Thread *t;
cell_t c;
real xc[ND_ND];
real variable;
thread_loop_c (t,d)
begin_c_loop (c,t)
C_CENTROID(xc,c,t);
xp = 0.0125;
epsilon = 0.052632;
sum = 0;
delta = 1;
n=38;
for (i=1 ; i=n ; 1)
yp = -10-(i/38);
r = pow((xc[0]-xp),2) + pow((xc[1]-yp),2);
term1 = exp(-pow(r/epsilon,2));
eta = term1*(1/M_PI*epsilon*epsilon*delta);
sum = sum + eta;
C_UDSI(c,t,0) = sum*500000;
C_UDSI(c,t,1) = r;
end_c_loop(c,t)
PierceH is offline   Reply With Quote
Old   February 2, 2022, 20:48
Alexander
AlexanderZ will become famous soon enoughAlexanderZ will become famous soon enough
check this condition
for (i=1 ; i=n ; 1)
use C language
best regards
press LIKE if this message was helpful
AlexanderZ is offline   Reply With Quote
Input part for automated mesh (2D) ReubenBuehler STAR-CCM+ 4 November 2, 2018 07:58
part remesh for optimization Marien ANSA 1 May 9, 2017 03:08
[snappyHexMesh] snappyHexMesh can't create a fine Mesh from stl from Rhinoceros Taghi OpenFOAM Meshing & Mesh Conversion 13 May 4, 2017 16:48
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 14:30
what boundary condition is proper for simulation of shock-tube low pressure part? immortality OpenFOAM Running, Solving & CFD 0 May 2, 2013 14:22
